Offline Alerts
Mason
Hi there,
I recently learned one of my IP cameras was vandalized and only found out after I happened to walk by. I am curious if I can setup offline alerts for devices. Let's say after one hour.
Currently using three RT-AC68U routers in AiMesh with the RC4 beta. Also a big fan of Merlin.
Cheers,
Steve
Hi there,
Cheers,
Steve
No idea about the firmware but maybe the camera has software or app that will alert your phone or send an email as an alert.
Yes, but not nearly as effective in my case. The cameras jump around nodes and I can't set a threshold for X minutes from them.
how about something along these lines?
ping the camera periodically, if it fails then send email notification.
if ping -q -c 1 -W 1 cameraIP >/dev/null; then
  echo "The camera is up "
else
logger -t $(basename $0) "Unable to reach camera"
# insert email notification script/path here.
fi
then use a cron job to run the above script .
else
fi
Can you give an example of how to send an email from a command line/script?
