It only supports 10/100mb. Buy a switch. 1gb switch is only for $10 to 20$ bucks. It's so cheap.I'd like to set up multiple network printers on a single cat5 cable. I have an old Netgear WNR 1500 router that I think could function as a switch of sorts but I can't figure out how to set this up.
Suggestions appreciated. Thank you -
Most printer's Ethernet ports, at least for home printers, only have 100 Mbps Ethernet ports no need to connect them to a gig switch port on a switch.It only supports 10/100mb. Buy a switch.
Some routers being repurposed as switches may require that you assign it an IP and gateway using its firmware. Other may allow you to assign it an IP using the networks router. Either way works but if you assign the IP on the device being repurposed it may only sporadically show up in a listing of attached clients.4. Assign it a LAN ip in the same range as the rest of your network.
Welcome To SNBForums
