Only allow OpenVPN connections to the outside (iptables)
BryanLee
I have a computer on my local LAN that I wish to only be able to make DNS queries and OpenVPN connections to the outside world, everything else should be dropped. In other words, if it's VPN connection goes down, I want it cut off.
But I'm not sure how to do this... I thought this would work:
# iptables -A OUTPUT -p udp -s 192.168.76.7 --dport 53 -j ACCEPT
# iptables -A OUTPUT -p udp -s 192.168.76.7 --dport 1194 -j ACCEPT
# iptables -A OUTPUT -s 192.168.76.7 -j DROP
I entered those manually, and was going to add them to /jffs/scripts/firewall-start
However, entering those didn't work. Well, the first two might be working, but the firewall is definitely not blocking all other traffic.
Here is the output of my iptables -L (before additional rules)
Chain INPUT (policy ACCEPT)
target     prot opt source               destination
ACCEPT     all  --  anywhere             anywhere
ACCEPT     udp  --  anywhere             anywhere             udp dpt:1194
DROP       icmp --  anywhere             anywhere             icmp echo-request
ACCEPT     all  --  anywhere             anywhere             state RELATED,ESTABLISHED
DROP       all  --  anywhere             anywhere             state INVALID
PTCSRVWAN  all  --  anywhere             anywhere
PTCSRVLAN  all  --  anywhere             anywhere
ACCEPT     all  --  anywhere             anywhere             state NEW
ACCEPT     udp  --  anywhere             anywhere             udp spt:bootps dpt:bootpc
INPUT_ICMP  icmp --  anywhere             anywhere
Chain FORWARD (policy DROP)
ipttolan   all  --  anywhere             anywhere
iptfromlan  all  --  anywhere             anywhere
NSFW       all  --  anywhere             anywhere
ACCEPT     all  --  anywhere             anywhere             ctstate DNAT
Chain OUTPUT (policy ACCEPT)
Chain ACCESS_RESTRICTION (0 references)
Chain FUPNP (0 references)
ACCEPT     tcp  --  anywhere             gallifrey.ragon.org  tcp dpt:13945
ACCEPT     udp  --  anywhere             gallifrey.ragon.org  udp dpt:13945
Chain INPUT_ICMP (1 references)
RETURN     icmp --  anywhere             anywhere             icmp echo-request
RETURN     icmp --  anywhere             anywhere             icmp timestamp-request
ACCEPT     icmp --  anywhere             anywhere
Chain NSFW (1 references)
Chain PControls (0 references)
Chain PTCSRVLAN (1 references)
Chain PTCSRVWAN (1 references)
Chain SECURITY (0 references)
RETURN     tcp  --  anywhere             anywhere             tcpflags: FIN,SYN,RST,ACK/SYN limit: avg 1/sec burst 5
DROP       tcp  --  anywhere             anywhere             tcpflags: FIN,SYN,RST,ACK/SYN
RETURN     tcp  --  anywhere             anywhere             tcpflags: FIN,SYN,RST,ACK/RST limit: avg 1/sec burst 5
DROP       tcp  --  anywhere             anywhere             tcpflags: FIN,SYN,RST,ACK/RST
RETURN     icmp --  anywhere             anywhere             icmp echo-request limit: avg 1/sec burst 5
RETURN     all  --  anywhere             anywhere
Chain iptfromlan (1 references)
RETURN     all  --  anywhere             anywhere            account: network/netmask: 192.168.76.0/255.255.255.0 name: lan
Chain ipttolan (1 references)
Chain logaccept (0 references)
LOG        all  --  anywhere             anywhere             state NEW LOG level warning tcp-sequence tcp-options ip-options prefix "ACCEPT "
Chain logdrop (0 references)
LOG        all  --  anywhere             anywhere             state NEW LOG level warning tcp-sequence tcp-options ip-options prefix "DROP "
Can anyone help?
The FORWARD chain is for traffic passing through the router. The OUTPUT chain is for traffic that originates at the router itself. Try this?
#!/bin/sh
# iptables -I FORWARD -s 192.168.76.7 -j DROP
# iptables -I FORWARD -i br0 -p udp -s 192.168.76.7 --dport 1194 -j ACCEPT
# iptables -I FORWARD -i br0 -p udp -s 192.168.76.7 --dport 53 -j ACCEPT
#!/bin/sh
Works great, thank you! Both the rules, and the startup script (after enabling scripts in the web gui).
