Open VPN version
bobpow
I did a search but really could not find any info.
Which version of OpenVPN is running on the current version of Merlin 384.11? Is it 2.4?
Thank You
Thank You
I was able to find it . it is 2.4.7
In case anyone is looking for the same info in future, where did you find the version number?
Just type openvpn in PuTTY. :)
Or you can specify:
openvpn --version
Or you can specify:
openvpn --version
Or you can look in your logs and it is in the first line of the open client vpn process. As the tunnel is being established
Using grep, we can clean up the output. I placed the function ovpnvers in /jffs/configs/profile.add as follows:
ovpnvers () {
  openvpn --version | grep -m1 -oE '[0-9]{1,2}([.][0-9]{1,2})([.][0-9]{1,2})'
Now, type the command ovpnvers from the command line:
# ovpnvers
2.4.7
