Openconnect Client Entware
ASadani
Hi All, I have searched extensively and believe there is an openconnect client with entware. The guides all seem to land up with a complexity of routing and reconnecting. Is there a UI applet installer that can be used to use the openconnect protocol instead.
I believe the openconnect through entware cannot restart on itself. and does not do an IP routing correctly. For example some exclusions. Any suggestions? Much appreciate
http://entware.net/about/ would be the place to start...openconnect is listed on the repo list for my architecture, so it probably is for yours as well.
I would think that for support for dealing with your particular issues, you'd have to go to Cisco, but there may be someone here who can help if they see this.
