Entware OpenSSH is getting killed by... something.
unsynaps
Best I can tell I have OpenSSH installed properly. Using the same ansible scriptsI used before to get it installed and working.
But for some reason now the sshd process is killed seconds after launching. No errors in even the debug logs for sshd. Even running it via /opt/sbin/sshd -D it just says "killed" after a second or two.
At a loss as to why this is happening.
Oh yes and I know about the bug in /opt/etc/ssh/sshd_config. Fixed that after some hair pulling. Issue still persists.
You can install strace from Entware and run strace /opt/sbin/sshd -D and see what system calls appear before being killed.
It's possibly killed by Asus' security daemon. A number of malware disguise themselves as the sshd process.
For the love of... I think this is it. Renamed /opt/sbin/sshd to <face+keyboard> and it doesn't get killed.
This must be something "new" as I never had this issue in the past.
Is there a more "elegant" way of dealing with this?
Ahh looks like I am going to have to add some sed tasks to my playbooks modifying the init.d scrips and such.
Ahh well. Thanks for the info RMerlin.
FYI,
I haven't had any problems at all running the OpenSSH server on my RT-AC86U with the latest 3004.386.14.2 F/W version. I have the latest OpenSSH server package from Entware. Perhaps the ASD behavior is different on the 3004.388.8.4 versions.
BTW, I do have a watchdog for the OpenSSH server (via a cron job) and, so far, it has not logged any events indicating that it had to restart the "sshd" process because it was not found.
Just a data point.
