OpenVPN Client & AI Protection - DNS Filtering
Aaron Payne
I am hoping someone can help. My usecase is simple. I want to tunnel all traffic via the my configured VPN client (configured & working) but retain the DNS filter controls. When I enable the VPN it breaks the AI Protection DNS Filtering rules. I assume this is because the VPN client pushes out new DNS server addresses.
Anyone know how I can accomplish this? I guess I need the router to hour the AI Protection DNS Address and ignore the ones being sent back to the VPN client.
Set the Accept DNS Configuration to Disabled in the VPN client settings.
Thanks for your reply but this had no affect.
Under LAN Settings --> DHCP Server --> DNS Server 1 = 8.8.8.8
Advertise Routers IP in addition to specified DNS = NO
Forward local domain queries to upstream DNS = NO
AI Protection --> DNS Filtering
Enable DNS Filtering = ON
Global Filter Mode = "No Filtering"
Then I have a list of specific clients e.g
KidsMac Filter Mode = "Norton Children"
KidsiPad Filter Mode = "Norton Children"
OpenVPN Clients
Accept DNS Configuration = Disabled
If I turn the VPN client Off all filtering works correctly. If I turn the VPN client on filtering does not work, adult website material is accessible from "KidsMac"
Is this a bug or have I missed something?
OpenVPN Clients
One additional configuration parameter.
WAN --> WAN DNS Setting --> Connect to DNS Server Automatically = NO
Its seems like the firmware (378.56_2) has a bug where it ignores all local DNS Settings if the VPN client is enabled.
One other thought. Maybe AIProtection - DNS Filtering is ignored if a VPNClient is configured.
Can anyone help?
Here is the ilpleak data you requested. over VPN it doesn't seem to show any DNS servers.
  • IP:DNS Detect VPN ENABLED.pdf
  • IP:DNS Detect VPN DISABLED.pdf
