I've had a pretty stable router for some time, the R66U. I don't use the Wifi, that's turned off as I have Unify, so I had no need to upgrade the router. I see now the Merlin updates won't be forthcoming any longer for this model.
Then a few months ago I switched to a new internet provider, and soon started getting the DHCP errors. I found references to WANduck and put in a script a few days ago, which appears to have sorted it. Except now both the OpenVPN client and server now have stopped functioning with :
Apr 8 22:10:17 rc_service: httpd 270:notify_rc start_vpnclient1
Apr 8 22:10:17 openvpn[1961]: Options error: You must define CA file (--ca) or CA path (--capath)
Apr 8 22:10:17 openvpn[1961]: Use --help for more information.
Given I had to create a JFFS partition to create the WANduck, any chance that's what's gone and borked the VPN? I've tried turning that off, and the 30 second powerdown, but nothing. Next steps would be a total factory reset and start again, but curious if there's any experience here with this before I go down that route.
Thanks everyone!
Thanks everyone!
