openvpn client issue
rayluc
i have a rt-ac68u running 3.0.0.4.374.43_2-03j9527 merlin fork. I have redirect internet traffic enable on my openvpn client but i don't see a place where i could add the ip address for the redirect. Am i missing something or is there an issue with this build?
Need to upgrade to a newer release.
Can I not go from the merlin fork back to the regular merlin? I tried upgrading to the latest merlin thru the web gui and recovery mode and the upgrade seem to run thru successfully but after the router reboots it's still on the same firmware.
Both John's latest and my own latest will provide policy-based routing.
The RT-AC68U can sometimes be tricky to upgrade due to the switch from a 32 MB firmware partition to 64 MB. Try upgrading to 378.53 first, after that you should be able to upgrade to 378.56_2.
I thought it was .50 then latest? Just bought 68P few days ago, and that worked without problems.
There are a few different past releases that can handle the partition upgrade. I don't know the exact list of versions that can do it, as I don't know at which point it stopped working. Any of the early 378.xx builds should do.
