OpenVPN Client, policy based routing issue
sfisher
Just got my hands on a Netgear R7000 and successfully installed Asuswrt-Merlin so I can run OpenVPN Client.
Issue is I'd like to have only select devices use the OpenVPN Tunnel so naturally what I have read on this forum today and the wiki https://github.com/RMerl/asuswrt-merlin/wiki
As I understand it, it should be as simple as setting:
Redirect Internet traffic: Policy Rules
Block routed clients if tunnel goes down: Yes (optional)
Rules for routing client traffic through the tunnel:
Source IP -> 10.0.1.14 Destination IP -> (blank) or 0.0.0.0 Ifac -> VPN
My results are All devices go through WAN (local IP) successfully. However the Device on 10.0.1.14 hangs and then returns page not available?
Switch Redirect Internet traffic: All Traffic and the results is all Devices go through the VPN as expected. (Shows my ip address as VPN)
Note I have done a Reboot after applying the setting and no change even if left for 10 to 20 min.
What am I doing wrong or have over looked? I feel like it is right there but I can't see the forest.
More information about the setup, if it helps...
NetGear R7000
Firmware 380.57
Router address is 10.0.1.1/26 (subnet mask 255.255.255.192) I choose to limit the number of hosts to 62.
DHCP Server is setup to hand out IP address from 10.0.1.52 to 10.0.1.62
Enable Manual Assignment: Yes
Manually Assigned IP around the DHCP list: I have 13 IP's assigned to devices MAC from 10.0.1.2 to 10.0.1.14
Most devices are LAN ethernet but a few are wireless only.
reading the forums here this seems to be a common issue for first time users. And the advice looked easy but it has proven to get the best of me and my current network skills.
Sorry but Netgear R7000 isnt supported by RMerlins fork.
Supported devices are ASUS:
* RT-N66U
* RT-AC66U
* RT-AC56U
* RT-AC68U
* RT-AC68P
* RT-AC87U
* RT-AC3200
* RT-AC88U
* RT-AC3100
* RT-AC5300
Thanks Octopus, I have now read that same info form Vortex that created the AsusWRT branch I am using. I will ask on that forum.
Thank you to RMerlin for making this possible and all the others here that support this community.
