OpenVPN Client Windows vs. Linux Nested (or cascading) tunnel behavior
rfmodulator
Greetings,
I have installed OpenVPN on a Windows 10 box and a Kali Linux box.
On Windows, a second VPN connection is routed through the first VPN connection.
On Linux, a second VPN connection is routed outside of the first VPN connection.
I believe both cases to be the default behavior because I haven't done anything particularly special.
On Windows I had to add the second TAP adapter.
On both boxes I simply import the .ovpn files and connect.
How should I configure OpenVPN on Linux so it will behave like it does on Windows?
Thanks!
