cosycactus
I have the following setup
1. Static IP Internet connection connected to WAN port of the router (AC68U with Merlin 3.0.0.4.374.39_0 firmware.
after configuring the Open VPN Client I get the following error in the system log
Mar 25 07:26:09 openvpn[4018]: Socket Buffers: R=[120832->131072] S=[120832->131072]
Mar 25 07:26:09 openvpn[4018]: UDPv4 link local: [undef]
Mar 25 07:26:09 openvpn[4018]: UDPv4 link remote: [AF_INET]46.28.49.140:2049
Mar 25 07:27:09 openvpn[4018]: TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Mar 25 07:27:09 openvpn[4018]: TLS Error: TLS handshake failed
Mar 25 07:27:09 openvpn[4018]: SIGUSR1[soft,tls-error] received, process restarting
Mar 25 07:27:09 openvpn[4018]: Restart pause, 2 second(s)
Mar 25 07:27:11 openvpn[4018]: Socket Buffers: R=[120832->131072] S=[120832->131072]
Mar 25 07:27:12 openvpn[4018]: UDPv4 link local: [undef]
Mar 25 07:27:12 openvpn[4018]: UDPv4 link remote: [AF_INET]46.28.49.140:2049
Mar 25 07:28:12 openvpn[4018]: TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Mar 25 07:28:12 openvpn[4018]: TLS Error: TLS handshake failed
Mar 25 07:28:12 openvpn[4018]: SIGUSR1[soft,tls-error] received, process restarting
Mar 25 07:28:12 openvpn[4018]: Restart pause, 2 second(s)
Mar 25 07:28:14 openvpn[4018]: Socket Buffers: R=[120832->131072] S=[120832->131072]
Mar 25 07:28:14 openvpn[4018]: UDPv4 link local: [undef]
Mar 25 07:28:14 openvpn[4018]: UDPv4 link remote: [AF_INET]83.170.117.176:2049
Configuration
1. Firewall is off in the router
# Automatically generated configuration
daemon
client
dev tun11
proto udp
remote vpn.ivpn.net 2049
resolv-retry infinite
nobind
persist-key
persist-tun
comp-lzo adaptive
cipher AES-256-CBC
redirect-gateway def1
verb 3
ca ca.crt
cert client.crt
key client.key
auth-user-pass up
status-version 2
status status
# Custom Configuration
client
nobind
persist-tun
persist-key
pull
ns-cert-type server
I am able to connect my laptop as openVPN client behind the router..
Not sure where is the problem
Configuration
daemon
client
dev tun11
proto udp
nobind
persist-key
persist-tun
comp-lzo adaptive
cipher AES-256-CBC
verb 3
ca ca.crt
cert client.crt
key client.key
auth-user-pass up
status-version 2
status status
client
nobind
persist-tun
persist-key
pull
ns-cert-type server
