OpenVPN clients attempting to start?
Christopher Manns
Asus RT-AC3100, 384.13
Aug 6 14:35:12 rc_service: ntpd_synced 829:notify_rc start_vpnclient1
Aug 6 14:35:12 rc_service: ntpd_synced 829:notify_rc start_vpnclient2
Aug 6 14:35:12 rc_service: waitting "start_vpnclient1" via ntpd_synced ...
Aug 6 14:35:16 rc_service: ntpd_synced 829:notify_rc start_vpnclient5
Aug 6 14:35:16 rc_service: waitting "start_vpnclient2" via ntpd_synced ...
Aug 6 14:35:19 ovpn-client2[1063]: Options error: You must define CA file (--ca) or CA path (--capath)
Aug 6 14:35:23 ovpn-client5[1225]: Options error: You must define CA file (--ca) or CA path (--capath)
Aug 6 14:35:29 nat: apply nat rules (/tmp/nat_rules_eth0_eth0)
Aug 6 14:35:29 crond[328]: time disparity of 660510 minutes detected
Aug 6 14:35:31 rc_service: udhcpc 725:notify_rc stop_vpnclient1
Aug 6 14:35:31 rc_service: udhcpc 725:notify_rc start_vpnclient1
Aug 6 14:35:31 rc_service: waitting "stop_vpnclient1" via udhcpc ...
Aug 6 14:35:31 ovpn-client1[1050]: event_wait : Interrupted system call (code=4)
Aug 6 14:35:34 rc_service: udhcpc 725:notify_rc start_vpnclient2
Aug 6 14:35:34 rc_service: waitting "start_vpnclient1" via udhcpc ...
Aug 6 14:35:36 rc_service: udhcpc 725:notify_rc start_vpnclient5
Aug 6 14:35:36 rc_service: waitting "start_vpnclient2" via udhcpc ...
Aug 6 14:35:38 ovpn-client2[1912]: Options error: You must define CA file (--ca) or CA path (--capath)
Aug 6 14:35:39 dhcp_client: bound xx.xx.xx.xx via xx.xx.xx.xx during 1800 seconds.
Aug 6 14:35:42 ovpn-client5[1963]: Options error: You must define CA file (--ca) or CA path (--capath)
I don't have clients 2 and 5 configured but for some reason, they are trying to start? and then of course fail. It doesn't seem to cause any problems but wondering what I can do to clean that up.
Only disable it for 2 and 5
My rt ac 88 u was doing the same thing after every reboot until I realized that i had the start VPN on rebooting box set to yes same fix turned both off and set run VPN after reboot to off of course
