OpenVPN Connect on Windows doesn't change IP but on Android it does
ChackieJan
Hello all,
I have a VPN server configured on a Asus RT-AC1900 running Merlin 386.10 with the below settings. I export the .ovpn configuration, and I'm able to connect fine on my Android device using OpenVPN Connect. I check whatismyipaddress.com, and I see that it shows up as an IP from my home ISP. I disconnect from OpenVPN on my phone and enable tethering so my W11 laptop can connect to my phone. Without connecting to OpenVPN on my laptop, I go to check my IP and it shows up as T-Mobile, my mobile carrier. I turn on OpenVPN on my laptop and try again. This time it still detects my ISP as T-Mobile even though I'm connected to my home VPN. Am I doing something wrong?
Interface TypeTUN
ProtocolUDP
Authentication ModeTLS
Username/Password AuthenticationYes
Username / Password Auth. OnlyNo
TLS control channel securityEncrypt Channel
HMAC AuthenticationSHA-1
Advertise DNS to clientsNo
Data ciphersCHACHA20-POLY1305:AES-128-GCM:AES-256-GCM:AES-128-CBC:AES-256-CBC
CompressionDisabled
Manage Client-Specific OptionsNo
Custom Configurationpush "redirect-gateway def1"
Client will use VPN to accessBoth (LAN and Internet)
I think when your phone is in "tethering mode" it only uses the mobile connection, not the Wi-Fi. Do you really mean tethering, i.e. your phone is connected to the laptop with a USB cable? Or do you mean the phone is operating as a Wi-Fi hotspot?
I mean when my phone is used as a wifi hotspot. I connect from my laptop to the wifi generated from my phone.
