OpenVPN CRL - strange problem
AndreyPopov
I make own mod for Merlin firmware with only one instance of OpenVPN server and client and try store all keys and certificates on jffs - to free nvram
all work like I plan except:
nvram key always after start OpenVPN Server sets with full certificate
vpn_crt_server_crl=---------------- BEGIN CERTIFICATE --------------
but this key must contain revocation list.
- in openvpn.c exist code to create crl.pem if vpn_crt_server_crl not empty
- only one place when vpn_crt_server_crl can sets is Advanced_VPN_OpenVPN in "Key and Certification" popup window.
but when reset to Factory Default - this window is empty
after start OpenVPN server key become
my aid is free nvram and move all keys and certificate to jffs. but unknow thread always sets vpn_crt_server_crl to certificate.
please, all who use OpenVPN, check your vpn_crt_server_crl or vpn_crt_server1_crl or vpn_crt_server2_crl keys - they empty or filled?
My CRL fields are empty here.
finded and solved.
when try store certificates and keys on jffs (not in nvram) - some files like ca.crt must be copied to client.ovpn
I use next:
sprintf(fpath, "/etc/openvpn/server/ca.crt", serverNum);
fp = fopen(fpath, "r");
set_crt_parsed(&buffer[0], fpath); //read from file to nvram
fprintf(fp_client, "%s", get_parsed_crt(&buffer[0], buffer2)); //write to file from nvram
&buffer[0] is temp variable, but unfortunatly previously operation was:
sprintf(&buffer[0], "vpn_crt_server_crl", serverNum);
and
write to nvram vpn_crt_server_crl :(
add some lines before and after (add temp nvram)
nvram_set("vpn_tmp","");
sprintf(&buffer[0], "vpn_tmp");
nvram_unset("vpn_tmp");
now work!
thanks
need help again.
OpenVPN not want autostart start after reboot.
what algorithm to autostart?
378.50 code relies on the new vpn_serverx_start variable rather than the old vpn_serverx_eas one, which was colliding with Asus's way of using it.
I already modified source after 378.3913 merge.
where autostart must be checked?
vpn_serverx_start now sets to "1,"
VPNServer_enable=1
vpn_server_state=2
from VPN-OpenVPN start-stop work.
one more question:
after 378.3913 merge status icons WiFi, Guest, WAN - not active
it always gray and even point mouse - nothing happen/
what hardware specific modofocation of state.js in 3913 that can block status icons?
please, when you have free time says me why:
www/state.js
this code
from https://github.com/RMerl/asuswrt-merlin/blob/master/release/src/router/www/state.js#L2830
to https://github.com/RMerl/asuswrt-merlin/blob/master/release/src/router/www/state.js#L2849
can break status icons and Internet status
attachment.php
but the code
from https://github.com/RMerl/asuswrt-me...142cef1/release/src/router/www/state.js#L2628
to https://github.com/RMerl/asuswrt-me...142cef1/release/src/router/www/state.js#L2643
work well
attachment.php
The order of the entries in the parsed XML data matters. You can't mix my JS code with Asus's XML file, and vice-versa. My code has a few additioonal entries to handle the two openvpn server instances among things.
