I'm using N66U with Merlin build. My OVN is in TUN mode.
I'm trying to fix IPs for all clients. So I created the ccd folder and all the files for clients. It worked fine.
However, when I rebooted the router (or off and on the OVN server), all the files in ccd folder disappeared. I had to create them again.
Is there anyway to retain the files manually created after reboot?
Thanks.
Thanks.
