SNBForums
This is a sample guest message. Register a free account today to become a member! Once signed in, you'll be able to participate on this site by adding your own topics and posts, as well as connect with other members through your own private inbox!
OpenVPN - generating additional client keys
wayner
So I have successfully set up OpenVPN using my router as the server and an iPad as the client.
I want to now set up some additional clients. Following the directions here do I just do the step of generating a new client key? Or do I have to rebuild the dh as well? That step always seems to come last in all OpenVPN tutorials that I have read and I am worried that if I just try to build a client key it will cause problems since that may be required to be done after building all server and client keys.
And when I build the client key what do I use for the common name? Do I use the name that I am putting in the command line, ie ./build-key iPhone1 - so do I now use iPhone one for the common name or do I use the same common name as I used when building the server key?
In addition, when I do the "Export ovpn file" from the Merlin web GUI - how do I know what client is being exported? Or does it matter? Can I use this one ovpn file with multiple clients?
when you use build-key whatever, you are just creating the key file names with the name 'whatever'. then you go through the script, just make sure the common name is unique; it will help you identify who/what is connecting in vpn status, too. i also set the 'name' to the common name, and pretty much auto-fill the rest with the script.
the diffie-hellman key is used [edit] to generate a shared secret [/edit] before the real encryption starts. at any time, you can generate a new one and replace the old without affecting any of the other keys, etc. afaik, larger DH keys provide like more possibilities of salts during encryption. too small and i guess there's more collisions/less randomness and the potential for like a quantum computer bruteforcing aes increases, or something to that effect. not an expert, so don't take this for gospel.
i have not used the export feature, but i believe it's designed to generate your basic configs and the keys are added to a folder containing the config, etc. i've only been using INLINE configurations, which i like because it means handling only a single file, but this way each OVPN will be unique to the user/device, thus requiring a bit more work
