Greetings,
Donator seeking tech support. I was trying to setup OpenVPN connection in my ASUS AC68U with Merlin 380.68_4 loaded up.
Any help, greatly appreciated! Thanks1
-b
Here is what I get from the Log:
Oct 16 14:52:59 openvpn[22286]: OpenVPN 2.4.3 arm-unknown-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD] built on Oct 4 2017
Oct 16 14:52:59 openvpn[22286]: library versions: OpenSSL 1.0.2l 25 May 2017, LZO 2.08
Oct 16 14:52:59 openvpn[22287]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Oct 16 14:52:59 openvpn[22287]: Outgoing Control Channel Authentication: Using 256 bit message hash 'SHA256' for HMAC authentication
Oct 16 14:52:59 openvpn[22287]: Incoming Control Channel Authentication: Using 256 bit message hash 'SHA256' for HMAC authentication
Oct 16 14:52:59 openvpn[22287]: TCP/UDP: Preserving recently used remote address: [AF_INET6]2001:1af8:4700:a039:8::1:1194
Oct 16 14:52:59 openvpn[22287]: Socket Buffers: R=[122880->122880] S=[122880->122880]
Oct 16 14:52:59 openvpn[22287]: UDP link local: (not bound)
Oct 16 14:52:59 openvpn[22287]: UDP link remote: [AF_INET6]2001:1af8:4700:a039:8::1:1194
Oct 16 14:52:59 openvpn[22287]: write UDP: Network is unreachable (code=101)
Oct 16 14:52:59 openvpn[22287]: Network unreachable, restarting
Oct 16 14:52:59 openvpn[22287]: SIGUSR1[soft,network-unreachable] received, process restarting
Oct 16 14:52:59 openvpn[22287]: Restart pause, 5 second(s)
Oct 16 14:53:04 openvpn[22287]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Oct 16 14:53:04 openvpn[22287]: TCP/UDP: Preserving recently used remote address: [AF_INET]5.79.77.168:1194
Oct 16 14:53:04 openvpn[22287]: Socket Buffers: R=[122880->122880] S=[122880->122880]
Oct 16 14:53:04 openvpn[22287]: UDP link local: (not bound)
Oct 16 14:53:04 openvpn[22287]: UDP link remote: [AF_INET]5.79.77.168:1194
Oct 16 14:53:04 openvpn[22287]: TLS: Initial packet from [AF_INET]5.79.77.168:1194, sid=1650db48 5a705c7a
Oct 16 14:53:04 openvpn[22287]: WARNING: this configuration may cache passwords in memory -- use the auth-nocache option to prevent this
Oct 16 14:53:05 openvpn[22287]: VERIFY OK: depth=1, C=CA, ST=Ontario, O=Whatbox Inc., CN=OpenVPN
Oct 16 14:53:05 openvpn[22287]: VERIFY KU OK
Oct 16 14:53:05 openvpn[22287]: Validating certificate extended key usage
Oct 16 14:53:05 openvpn[22287]: ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
Oct 16 14:53:05 openvpn[22287]: VERIFY EKU OK
Oct 16 14:53:05 openvpn[22287]: VERIFY OK: depth=0, C=CA, ST=Ontario, O=Whatbox Inc., CN=*.whatbox.ca, emailAddress=support@whatbox.ca
Oct 16 14:53:05 openvpn[22287]: Control Channel: TLSv1.2, cipher TLSv1/SSLv3 ECDHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
Oct 16 14:53:05 openvpn[22287]: [*.whatbox.ca] Peer Connection Initiated with [AF_INET]5.79.77.168:1194
Oct 16 14:53:06 openvpn[22287]: SENT CONTROL [*.whatbox.ca]: 'PUSH_REQUEST' (status=1)
Oct 16 14:53:06 openvpn[22287]: PUSH: Received control message: 'PUSH_REPLY,dhcp-option DNS 8.8.8.8,dhcp-option DNS 8.8.4.4,redirect-gateway def1,route-ipv6 2000::/3,redirect-gateway ipv6,tun-ipv6,route 10.8.0.1,topology net30,ping 10,ping-restart 120,ifconfig-ipv6 2001:1af8:4700:a039:8::1002/112 2001:1af8:4700:a039:8::2,ifconfig 10.8.0.10 10.8.0.9,peer-id 1,cipher AES-256-GCM'
Oct 16 14:53:06 openvpn[22287]: Note: option tun-ipv6 is ignored because modern operating systems do not need special IPv6 tun handling anymore.
Oct 16 14:53:06 openvpn[22287]: OPTIONS IMPORT: timers and/or timeouts modified
Oct 16 14:53:06 openvpn[22287]: OPTIONS IMPORT: --ifconfig/up options modified
Oct 16 14:53:06 openvpn[22287]: OPTIONS IMPORT: route options modified
Oct 16 14:53:06 openvpn[22287]: OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
Oct 16 14:53:06 openvpn[22287]: OPTIONS IMPORT: peer-id set
Oct 16 14:53:06 openvpn[22287]: OPTIONS IMPORT: adjusting link_mtu to 1625
Oct 16 14:53:06 openvpn[22287]: OPTIONS IMPORT: data channel crypto options modified
Oct 16 14:53:06 openvpn[22287]: Data Channel: using negotiated cipher 'AES-256-GCM'
Oct 16 14:53:06 openvpn[22287]: Data Channel Encrypt: Cipher 'AES-256-GCM' initialized with 256 bit key
Oct 16 14:53:06 openvpn[22287]: Data Channel Decrypt: Cipher 'AES-256-GCM' initialized with 256 bit key
Oct 16 14:53:06 openvpn[22287]: GDG6: remote_host_ipv6=n/a
Oct 16 14:53:06 openvpn[22287]: TUN/TAP device tun11 opened
Oct 16 14:53:06 openvpn[22287]: TUN/TAP TX queue length set to 100
Oct 16 14:53:06 openvpn[22287]: do_ifconfig, tt->did_ifconfig_ipv6_setup=1
Oct 16 14:53:06 openvpn[22287]: /usr/sbin/ip link set dev tun11 up mtu 1500
Oct 16 14:53:06 openvpn[22287]: /usr/sbin/ip addr add dev tun11 local 10.8.0.10 peer 10.8.0.9
Oct 16 14:53:06 openvpn[22287]: /usr/sbin/ip -6 addr add 2001:1af8:4700:a039:8::1002/112 dev tun11
Oct 16 14:53:06 openvpn[22287]: Linux ip -6 addr add failed: external program exited with error status: 2
Oct 16 14:53:06 openvpn[22287]: Exiting due to fatal error
-b
