AlexanderD
Hello Forum!
I need help with VPN setup.
TL/DR:
OpenVPN Server clients do not have an IPv6 connection. The router itself and the clients inside the local network work without problems with IPv6.
My setup:
AX86U - Merlin 386.5_2
IPv4 - real static IP (Automatic)
IPv6 - HE.net tunnel
AdguardHome (AMTM script)
The problem is that vpn clients cannot connect to the IPv6 internet. IPv4 internet connection works fine. Is it possible to configure a VPN server in such a way that its clients, among other things, can have access to the IPv6 Internet? Do I need to configure routing or is it a firewall issue?
There is another thread: https://www.snbforums.com/threads/merlin-openvpn-ipv6-on-macos.77974/
In it, the user describes a similar problem, but his configuration partially works.
Thank you.
TL/DR:
My setup:
Thank you.
