My clients are not able to connect to the internet, nor able to RDP to pc's after getting connected to my openvpn server on rt-ac3100 running 384.13. They can, however, ping the pc's within the LAN without error.
They're using the latest OpenVPN client from google play..they're also using the Microsoft RDP application from google play. These are my client settings..
client
dev tun
proto udp
remote (address) (port#)
float
ncp-ciphers AES-128-GCM:AES-256-GCM
auth SHA256
compress lz4
keepalive 15 60
auth-user-pass
remote-cert-tls server
I also have the "Client will use VPN to access" radio button set to "Both".
The IP range giving out by the vpn server is 10.8.0.* and the local lan is 192.168.2.*...
Any ideas?
client
dev tun
proto udp
float
auth SHA256
compress lz4
keepalive 15 60
auth-user-pass
Any ideas?
