Rotsen24154
Hi.
I am trying to follow these instructions (https://www.snbforums.com/threads/o...-on-site-to-site-connection.24268/post-335476) to allow all the clients of my VPN has communication among them.
The problem is when I add the Custom Configuration like this:
The client-connect command is not saved in the server config.ovpn, so the script is never executed.
I tried adding --client-connect, adding quotes to the route, using a Hello World script, but the command disappears from the generated config.ovpn, this is an example of the final config.ovpn.
As you can see the # Custom Configuration section has all the lines except the client-connect.
I use a GT-AX6000 stock; the OpenVPN --version shows this information.
And sorry I am a super newbie on these, this is a personal project, and I don't have a lot of experience of networking or things like this.
I find nothing like this issue on the forum, that's why I ask for help![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Thank you.
script-security 2
# Assign static I/P addresses to clients (and optionally add ADVANCED CCD directives)
client-connect /jffs/scripts/VPNClientConnect.sh
route 192.168.3.0 255.255.255.0 vpn_gateway
route 192.168.4.0 255.255.255.0 vpn_gateway
push "route 192.168.3.0 255.255.255.0"
push "route 192.168.4.0 255.255.255.0"
Automatically generated configuration
# Tunnel options
proto udp6
multihome
port 1194
dev tun21
route-pre-down '/etc/openvpn/ovpn-route-pre-down'
sndbuf 0
rcvbuf 0
keepalive 10 30
up '/etc/openvpn/ovpn-up'
down '/etc/openvpn/ovpn-down'
setenv ovpn_type 0
setenv unit 1
script-security 2
daemon vpnserver1
verb 3
status-version 2
status status 10
compress lzo
plugin /usr/lib/openvpn-plugin-auth-pam.so openvpn
# Server Mode
server 10.8.0.0 255.255.255.0
duplicate-cn
push "route 192.168.50.0 255.255.255.0 vpn_gateway 500"
push "route 192.168.60.0 255.255.255.0 vpn_gateway 500"
# Data Channel Encryption Options
auth SHA1
cipher AES-128-CBC
ncp-disable
# TLS Mode Options
ca ca.crt
dh dh.pem
cert server.crt
key server.key
script-security 2
OpenVPN 2.4.12 arm-buildroot-linux-gnueabi [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD] built on May 15 2024
library versions: OpenSSL 1.1.1t 7 Feb 2023, LZO 2.10
Originally developed by James Yonan
Copyright (C) 2002-2018 OpenVPN Inc <sales@openvpn.net>
Compile time defines: enable_async_push=no enable_comp_stub=no enable_crypto=yes enable_crypto_ofb_cfb=yes enable_debug=no enable_def_auth=yes enable_dlopen=unknown enable_dlopen_self=unknown enable_dlopen_self_static=unknown enable_fast_install=yes enable_fragment=yes enable_iproute2=no enable_libtool_lock=yes enable_lz4=yes enable_lzo=yes enable_management=yes enable_multihome=yes enable_pam_dlopen=no enable_password_save=yes enable_pedantic=no enable_pf=yes enable_pkcs11=no enable_plugin_auth_pam=yes enable_plugin_down_root=yes enable_plugins=yes enable_port_share=yes enable_selinux=no enable_server=yes enable_shared=yes enable_shared_with_static_runtimes=no enable_small=no enable_socks=no enable_static=yes enable_strict=no enable_strict_options=no enable_systemd=no enable_werror=no enable_win32_dll=yes enable_x509_alt_username=no with_aix_soname=aix with_crypto_library=openssl with_gnu_ld=yes with_mem_check=no with_sysroot=no
Thank you.
