I have a similar error see below. Have you found the issue?:
Aug 3 19:07:44 ovpn-client2[8622]: Note: option tun-ipv6 is ignored because modern operating systems do not need special IPv6 tun handling anymore.
Aug 3 19:07:44 ovpn-client2[8622]: OpenVPN 2.6.3 arm-buildroot-linux-gnueabi [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD]
Aug 3 19:07:44 ovpn-client2[8622]: library versions: OpenSSL 1.1.1t 7 Feb 2023, LZO 2.10
Aug 3 19:07:44 ovpn-client2[8623]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Aug 3 19:07:44 ovpn-client2[8623]: TCP/UDP: Preserving recently used remote address: [AF_INET]xx.xx.xxx.xxx:50237
Aug 3 19:07:44 ovpn-client2[8623]: Socket Buffers: R=[131072->131072] S=[16384->16384]
Aug 3 19:07:44 ovpn-client2[8623]: Attempting to establish TCP connection with [AF_INET]xx.xx.xxx.xxx:50237
Aug 3 19:07:45 ovpn-client2[8623]: TCP connection established with [AF_INET]xx.xx.xxx.xxx:50237
Aug 3 19:07:45 ovpn-client2[8623]: TCPv4_CLIENT link local: (not bound)
Aug 3 19:07:45 ovpn-client2[8623]: TCPv4_CLIENT link remote: [AF_INET]xx.xx.xxx.xxx:50237
Aug 3 19:07:45 ovpn-client2[8623]: TLS: Initial packet from [AF_INET]xx.xx.xxx.xxx:50237, sid=a2e08b96 f868ac51
Aug 3 19:07:45 ovpn-client2[8623]: WARNING: this configuration may cache passwords in memory -- use the auth-nocache option to prevent this
Aug 3 19:07:45 ovpn-client2[8623]: VERIFY OK: depth=1, C=FR, O=Freebox SA, CN=Freebox OpenVPN server CA for
Aug 3 19:07:45 ovpn-client2[8623]: VERIFY KU OK
Aug 3 19:07:45 ovpn-client2[8623]: Validating certificate extended key usage
Aug 3 19:07:45 ovpn-client2[8623]: ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
Aug 3 19:07:45 ovpn-client2[8623]: VERIFY EKU OK
Aug 3 19:07:45 ovpn-client2[8623]: VERIFY X509NAME OK: C=FR, O=Freebox SA, CN=Freebox OpenVPN server
Aug 3 19:07:45 ovpn-client2[8623]: VERIFY OK: depth=0, C=FR, O=Freebox SA, CN=Freebox OpenVPN server
Aug 3 19:07:46 ovpn-client2[8623]: Control Channel: TLSv1.3, cipher TLSv1.3 TLS_AES_256_GCM_SHA384, peer certificate: 2048 bit RSA, signature: RSA-SHA256
Aug 3 19:07:46 ovpn-client2[8623]: [Freebox OpenVPN server] Peer Connection Initiated with [AF_INET]xx.xx.xxx.xxx:50237
Aug 3 19:07:46 ovpn-client2[8623]: TLS: move_session: dest=TM_ACTIVE src=TM_INITIAL reinit_src=1
Aug 3 19:07:46 ovpn-client2[8623]: TLS: tls_multi_process: initial untrusted session promoted to trusted
Aug 3 19:07:47 ovpn-client2[8623]: SENT CONTROL [Freebox OpenVPN server]: 'PUSH_REQUEST' (status=1)
Aug 3 19:07:47 ovpn-client2[8623]: PUSH: Received control message: 'PUSH_REPLY,ping 30,ping-restart 120,dhcp-option DNS 212.27.38.253,route 192.168.27.64 255.255.255.224,route 192.168.0.0 255.255.255.0,dhcp-option DNS fd0f:ee:b0::1,ifconfig-ipv6 2a01:e0a:170:3478::10/124 fd0f:ee:b0::1,ifconfig 192.168.27.65 212.27.38.253,peer-id 0,cipher AES-256-GCM'
Aug 3 19:07:47 ovpn-client2[8623]: OPTIONS IMPORT: --ifconfig/up options modified
Aug 3 19:07:47 ovpn-client2[8623]: OPTIONS IMPORT: route options modified
Aug 3 19:07:47 ovpn-client2[8623]: OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
Aug 3 19:07:47 ovpn-client2[8623]: TUN/TAP device tun12 opened
Aug 3 19:07:47 ovpn-client2[8623]: TUN/TAP TX queue length set to 1000
Aug 3 19:07:47 ovpn-client2[8623]: /usr/sbin/ip link set dev tun12 up mtu 1500
Aug 3 19:07:47 ovpn-client2[8623]: /usr/sbin/ip addr add dev tun12 local 192.168.27.65 peer 212.27.38.253
Aug 3 19:07:47 ovpn-client2[8623]: Linux ip addr add failed: external program exited with error status: 2
Aug 3 19:07:47 ovpn-client2[8623]: Exiting due to fatal error
