Following on from my earlier post https://www.snbforums.com/threads/remote-vpn-access-to-my-home-vpn.77019/ (thanks a lot for all responses),
I've got the following set-up:
1. ISP router with a public IP
2. GL.iNet GL-AR300M16 (GL-AR300M Series / Shadow) router with an OpenVPN server setup and running
The ISP router is set-up as a bridge. With a router mode, the IP is private, and when connected to it directly or through the Shadow router (without OpenVPN), I can see it's private:
However with a bridge mode it changes to public:
The Shadow router is connected as a repeater:
When I configure and export OpenVPN file I get:
The IP in line 4 is what I see when googling my IP address.
I can start the server but I can't connect it. I've tried different ways:
- from Android phone and Windows laptop
- from the same WiFi (connecting to the Shadow router) and through another internet provider
In all cases I can't connect.
Do you have suggestions what I'm doing wrong?
Thanks a lot!
Thanks a lot!
