OpenVPN server: client config file not available
ethician
On N66U and AC3200 (others possibly too), 380.68_4, the EXPORT button for client config file never becomes available. The reason is that the nvram variable vpn_server1_state stays 1. I checked the source code and by the end of the function call start_vpnserver() the state is set to 2 but only for cryptMode SECRET or CUSTOM, not TLS. That tells me that somewhere else the state gets set to 2 but I simply couldn't find it. If anybody has any insight into how this whole process works and where and how the vpn state is set, I would appreciate them sharing it.
I also checked the 378.53 branch and it seems the state gets set directly at the end of that function regardless of cryptMode.
The final state is set within the OpenVPN code, not in rc/openvpn.c.
This is embarrassing but I have to admit to it. I've upgraded OpenVPN to 2.4.4 not knowing about those custom changes...
You meant inside the firmware? Yes, there are a few patches done by Asus to handle connection report through nvram.
My advice when updating any built-in component is to download the code to both the current and the new version, diff them, and apply that diff on top of my code. That way, any present customization will be preserved.
For OpenVPN 2.4.4, even easier would be to just pick my own commit.
https://github.com/RMerl/asuswrt-me...149fc3d#diff-72c239a0350aee0a59f7ff01ffe1cc02
