OpenVPN server configuration
nastyjoe
Hi everyone,
I'm new to this awesome custom firmware. I've been fiddling around the features lately and now I have decided I want an OpenVPN server running so I could access my home network from remote locations. Unfortunately, at least iOS does not support TAP connections so I am forced to using TUN, and the real problem is that I am clueless as how to get other devices visible for the remote machine.
Could someone please give some advice as to how I should configure my RT-AC56u so that I could for example use iPrint from a remote location?
Thanks! :)
Hi everyone,
Thanks! :)
You can do tap if you jailbreak and install guizmovpn on your iOS device
Thank you thank you thank you for mentioning the name of that great app!! Now I can access my samba share from my iTouch easily!
Working fine on iOS 7.0.4 jailbroken
Sent from my SM-N9005 using Tapatalk
Been using it. It's worth all the money you pay for it
i understand that Merlins firmware can generate client and server keys automatically for OpenVPN. Does anyone know how to do this?
UPDATE:- Scratch that its done it!!
What's the price of the app? I have 7 days trial right now.
Purchased mine from inside the app. Make sure it works well for your first. I use it to connect to quite a few openvpn servers reliably
