OpenVPN server couldn't initialize since upgrade to 360.66 beta1
p1r473
I'm trying to setup OpenVPN server and it couldn't initialize. I used to have it working until I upgraded firmware to 380.66 beta 1 today.
It's not working for both #1 and #2 slots.
It's continuously showing following message under "Export OpenVPN configuration file" section:
Initialinzing the settings of OpenVPN server now, please wait a few minutes to let the server to setup completed before VPN clients establish the connection.
I find the following log messages:
Apr 26 12:22:39 openvpn[7114]: Options error: --up script fails with 'updown.sh': Permission denied
Apr 26 12:22:39 openvpn[7114]: Options error: Please correct this error.
Apr 26 12:22:39 openvpn[7114]: Use --help for more information.
Apr 26 12:22:39 syslog: VPN_LOG_ERROR: 1524: Starting VPN instance failed...
I've tried to reset to defaults, bit it doesn't help.
Router: AC5300
Firmware: 380.66_beta1
Do you have any /jffs/scripts/openvpn-event script?
Yes, I do, I have a netflix vpn bypass script:
https://github.com/RMerl/asuswrt-merlin/wiki/Policy-based-routing-(manual-method)
In openvpn-event:
for i in /proc/sys/net/ipv4/conf/*/rp_filter ; do
echo 0 > $i
done
ip route flush table 100
ip route del default table 100
ip rule del fwmark 1 table 100
ip route flush cache
iptables -t mangle -F PREROUTING
ip route show table main | grep -Ev ^default | grep -Ev tun11\
| while read ROUTE ; do
ip route add table 100 $ROUTE
done
ip route add default table 100 via $(nvram get wan_gateway)
ip rule add fwmark 1 table 100
#All devices bypass VPN
iptables -t mangle -A PREROUTING -i br0 -j MARK --set-mark 1
#ShieldTV uses VPN
iptables -t mangle -A PREROUTING -i br0 -m iprange --src-range 192.168.1.190 -j MARK --set-mark 0
#BlackPearl uses VPN
iptables -t mangle -A PREROUTING -i br0 -m iprange --src-range 192.168.1.69 -j MARK --set-mark 0
#Netflix bypass VPN
iptables -t mangle -A PREROUTING -i br0 -m iprange --dst-range 107.20.177.0-107.20.177.255 -j MARK --set-mark 1
iptables -t mangle -A PREROUTING -i br0 -m iprange --dst-range 107.20.154.0-107.20.154.255 -j MARK --set-mark 1
iptables -t mangle -A PREROUTING -i br0 -m iprange --dst-range 174.129.2.0-174.129.2.255 -j MARK --set-mark 1
iptables -t mangle -A PREROUTING -i br0 -m iprange --dst-range 75.101.139.0-75.101.139.255 -j MARK --set-mark 1
iptables -t mangle -A PREROUTING -i br0 -m iprange --dst-range 54.243.253.0-54.243.253.255 -j MARK --set-mark 1
iptables -t mangle -A PREROUTING -i br0 -m iprange --dst-range 50.19.210.0-50.19.210.255 -j MARK --set-mark 1
iptables -t mangle -A PREROUTING -i br0 -m iprange --dst-range 23.23.191.0-23.23.191.255 -j MARK --set-mark 1
iptables -t mangle -A PREROUTING -i br0 -m iprange --dst-range 54.204.2.0-54.204.2.255 -j MARK --set-mark 1
iptables -t mangle -A PREROUTING -i br0 -m iprange --dst-range 54.204.43.0-54.204.43.255 -j MARK --set-mark 1
iptables -t mangle -A PREROUTING -i br0 -m iprange --dst-range 54.225.192.0-54.225.192.255 -j MARK --set-mark 1
iptables -t mangle -A PREROUTING -i br0 -m iprange --dst-range 23.21.190.0-23.21.190.255 -j MARK --set-mark 1
iptables -t mangle -A PREROUTING -i br0 -m iprange --dst-range 107.20.151.0-107.20.151.255 -j MARK --set-mark 1
exit 1
Try to remove it and test if it's start. (just for test)
Yep, disabled the script and it works great thanks!
I will try to temporarily disable this script while I bring my server online!
okey see my second post about new change in openvpn policy table.
ok so I deleted the script, enabled the server successfully, then re-enabled the script, and now my clients can't connect to the server (says: "waiting for server reply")
Is there something I need to do to the script to get it to work with having both a client and server running simultanouesly?
Isnt your 2nd post about the new change, in the back end, and I don't have to do anything for it?
That reflect new policy rule. (You don't have to do anything)
I don't know how to modify your script, I'm using builtin Policy routing function.
Even without the script, I don't seem to be able to connect to my OpenVPN server if I am also running an OpenVPN client
Is there no way to run a client and server at same time? Trying to connect to my server (even without the script!) is giving "waiting for server reply" message
Here are my configs:
Okey I see you use only password/user only. I use full set of certificate.
You can always go back to alpha4 build.
Went back to alpha4, and seem, to have same issue, where my OpenVPN server won't work if my client is connected, even without the script
