openvpn server custom-config
Cake
Just noticed on ver 380.58 AC68U, OpenVPN Server--> the custom config bottom section on the advanced settings do not get transfered to the opvn file when you click to download it.
I could be mistaken, and I just need to reboot. I did toggle the openvpn server off and on, and re-downloaded the config file. Custom settings were still missing, and needed to be manually entered in.
If anyone cares.... :-)
This is normal. The Custom section is intended for server parameters. The router has no way of knowing which of the entries in this section would also apply to the client, or what would be the client equivalent parameter.
When you click on "Export", the router doesn't send you a copy of the server config. It sends you a completely separate file, which it generates based on the server configuration.
