OpenVPN Server on Asus RT-N66U Attack
utmx
Some details:
1. Asus stock firmware 3.0.0.4.382_52272
2. Embeded openvpn server
3. Firewall and dos-protection are enabled
Issue:
In recent weeks the issues randomly happen with the VPN server - new clients can't connect to it. Router still works. Every time before this case the router logs look something like this:
vpnserver1[]: xxx.xxx.xxx.xxx:44576 TLS: Initial packet from [AF_INET]xxx.xxx.xxx.xxx:44576 (via .....
vpnserver1[]: xxx.xxx.xxx.xxx:41474 TLS: Initial packet from [AF_INET]xxx.xxx.xxx.xxx:41474 (via .....
vpnserver1[]: xxx.xxx.xxx.xxx:25017 TLS: Initial packet from [AF_INET]xxx.xxx.xxx.xxx:25017 (via ..... ,
Where xxx.xxx.xxx.xxx - unknown random IP (Saudi Arabi, sometimes Italy, Holland, etc). Several hundred "initial" packets in a row, about 10 packets per second.
What is it? Attack? How to deal with this?
Thanks!
That's just the normal port scanning/hacking attempts you'll get by exposing router services to the internet on common ports. Change your VPN server so that it uses a random port between 10000 and 32000 (and not obvious ones like 10000, 20000, 11111, etc).
