OpenVPN Server - openvpn-event Problem
CaptMorgan
I'm running 380.63 on an RT-AC87U and think I've identified a bug in the openvpn-event implementation of the openvpn server.
I have an OpenVPN client connected to privateinternetaccess and routing all traffic from a couple of LAN devices except for a few ports on those devices that are directed through the internet gateway. The bypass is configured and executed by an openvpn-event script installed at /jffs/scripts/. It works fine.
The problem I'm experiencing is that I cannot run an openvpn server at the same time on the RT-AC87U. The openvpn server daemon fails to start. Troubleshooting has lead me to realize whenever the server attempts to start, it writes the contents of the /jffs/scripts/openvpn-event file to /etc/openvpn/server1/updown.sh.
No matter what is in the event file, it is written exactly into the updown.sh file. Renaming or deleting the event file allows both the openvpn client and server to coexist. I tried wiping and reflashing my router thinking it was something I may have done, but the problem remains.
If its something I'm doing wrong, I sure can't figure out what it is...any help is appreciated!
Thanks!
CaptMorgan!
There is a whole series of arguments that are passed to the openvpn-event script (you can see them in the syslog) as well as setting about a dozen environment variables. Your script has to see who called it and why and then take the proper actions.
Understood.
But I tried something as basic as disabling the client, and putting an event file containing nothing more than a comment in the file and got the same results; when starting the server the contents of the file were written to the updown.sh file.
Are you able to start an openvpn server when an openvpn-event file is present?
Yes, I'm currently running both an OpenVPN server and client. Currently on my Merlin fork code, but it also worked the last time I had loaded Merlin.
My openvpn-event script is set up basically as a 'director'. All it does is see what event called it, then calls the appropriate event specific script.
For example, a vpnclient1-route-up script.
Thanks for your responses john9527. I suspect your experience far outweighs mine. What you're doing with your script may very well be what I need to do to accomplish my end goal. But how does your response confirm there isn't a problem with 380.63?
On 380.63, can you run an openvpn server with an openvpn-event scrip? It doesn't work for me and since I've wiped and reflashed my router today in an attempt to fix the problem, I'm at a loss for an explanation.
I disabled the client, and put nothing more than a comment in the /jffs/scripts/openvpn-event file. When the server attempts to start, the contents of /jffs/scripts/openvpn-event were written to an /etc/openvpn/server1/updown.sh file and the server daemon fails to start. Without the openvpn-event file, the server runs fine.
Is anyone running an openvpn server on 380.63 and using an openvpn-event file?
