#TY
I am currently installing a new Asus AX88U at a clients office and its running the latest merlin firmware, 384.19.
I am trying to configure the OpenVPN server to allow staff members with the same router at home to always have their routers connected to the office OpenVPN server so that they can access the file server, etc.
The LAN IP structure at the office is 192.168.1.x (I know its not ideal but they have way too many things static with that structure that they don't want to go through the hassle of changing it).
I setup the OpenVPN to Lan only with pretty much the default setup. The only thing I enabled was the "Manage Client-Specific options" and I allowed Client to Client.
When I had left the initial VPN subnet to 10.8.0.0, I was able to connect to the VPN server but couldn't ping anything inside (i.e. 192.168.1.1).
Then I changed the VPN subnet to 192.168.0.0 and all of a sudden I was able to ping everything inside the local network and all is well.
My VPN client received an IP of 192.168.0.2
Then I setup someone else's Asus router to do the same thing and the odd thing is, they also connected no problem but their VPN Client also got the same IP I did (192.168.0.2) which seems a little unusual to me. The odd thing is that we're both able to connect to everything without any issue.
Is this normal? I've attached the setup below. Thanks to all in advance.
