Hello to all!
I describe my situation that is making me lose my mind:
I have 2 LAN and 2 routers RT-N66u and RT-N16.
My goal is to be able to access HDDs connected to the routers and also to access shares of both LAN PCs.
RT-N66U (with OpenVPN server) - 3.0.0.4.270.26 (Merlin build)
IP: 131.114.0.0
Mask: 255.255.255.0
Gateway: 131.114.0.1
OpenVPN: 10.8.0.1
RT-N16 (with OpenVPN Client) - Tomato Version 1.28 by shibby
IP: 192.168.0.0
Mask: 255.255.255.0
Gateway: 192.168.0.1
OpenVPN: 10.8.0.6
From Client I can ping and browse shares of Server
ViceVersa impossible
If i change and set RT-N16 OpenVPN server and RT-N66U OpenVPN Client.... is the same problem:
from client to server, no problem, i can ping also the PC behind the router.
From Server to Client impossible....
In Server i set "allow Client to Client" but the problem persist.
I tried disable firewalls on each router but without results.
I tried install DD-WRT on RT-N16 with the same problem.
I tried to set static routes but But I do not know how to set them, and I do not know if that's the problem.
It seems impossible that there is a way to do
Can you help me? I'm desperate :-(
Job
Edit: Only now I realized that Merlin has released a new firmware that supports RT-N16
I could also do this test but I think that the problem remains.
Since I did not even changing firmware changes, I fear that there is something to be set do not know.
IP: 131.114.0.0
Mask: 255.255.255.0
OpenVPN: 10.8.0.1
IP: 192.168.0.0
Mask: 255.255.255.0
OpenVPN: 10.8.0.6
Job
