IPv4 Route Table
Active Routes:
Network Destination Netmask Gateway Interface Metric
0.0.0.0 0.0.0.0 10.0.0.1 10.0.0.100 25
0.0.0.0 128.0.0.0 10.8.0.5 10.8.0.6 30
10.0.0.0 255.255.255.0 On-link 10.0.0.100 281
10.0.0.100 255.255.255.255 On-link 10.0.0.100 281
10.0.0.255 255.255.255.255 On-link 10.0.0.100 281
10.8.0.1 255.255.255.255 10.8.0.5 10.8.0.6 30
10.8.0.4 255.255.255.252 On-link 10.8.0.6 286
10.8.0.6 255.255.255.255 On-link 10.8.0.6 286
10.8.0.7 255.255.255.255 On-link 10.8.0.6 286
37.18.137.x 255.255.255.255 10.0.0.1 10.0.0.100 25
127.0.0.0 255.0.0.0 On-link 127.0.0.1 306
127.0.0.1 255.255.255.255 On-link 127.0.0.1 306
127.255.255.255 255.255.255.255 On-link 127.0.0.1 306
128.0.0.0 128.0.0.0 10.8.0.5 10.8.0.6 30
192.168.0.0 255.255.255.0 10.8.0.5 10.8.0.6 30
224.0.0.0 240.0.0.0 On-link 127.0.0.1 306
224.0.0.0 240.0.0.0 On-link 10.8.0.6 286
224.0.0.0 240.0.0.0 On-link 10.0.0.100 281
255.255.255.255 255.255.255.255 On-link 127.0.0.1 306
255.255.255.255 255.255.255.255 On-link 10.8.0.6 286
255.255.255.255 255.255.255.255 On-link 10.0.0.100 281
I had your same problem on my RT-AC68U with .40alpha4. Now I am trying out .41alpha5 and it worked with the same config. Looks like the "push LAN to clients" was broken on .40alpha4.
GNU nano 2.2.6 File: server1-fw.sh
#!/bin/sh
iptables -t nat -I PREROUTING -p udp --dport 1194 -j ACCEPT
iptables -I INPUT -p udp --dport 1194 -j ACCEPT
iptables -I INPUT -i tun21 -j ACCEPT
iptables -I FORWARD 4 -i tun21 -j ACCEPT
iptables -A ipttolan -i tun21 -m account --aaddr 192.168.0.0/255.255.255.0 --aname lan -j RETURN
iptables -A iptfromlan -o tun21 -m account --aaddr 192.168.0.0/255.255.255.0 --aname lan -j RETURN
# Automatically generated configuration
daemon
server 10.8.0.0 255.255.255.0
proto udp
port 1194
dev tun21
comp-lzo adaptive
keepalive 15 60
verb 3
push "route 192.168.0.0 255.255.255.0"
push "dhcp-option DNS 192.168.0.1"
push "redirect-gateway def1"
tls-auth static.key
plugin /usr/lib/openvpn-plugin-auth-pam.so openvpn
duplicate-cn
ca ca.crt
dh dh.pem
cert server.crt
key server.key
status-version 2
status status
# Custom Configuration
admin@RT-N66U:/tmp/home/root# iptables -L -n
Chain INPUT (policy ACCEPT)
target prot opt source destination
ACCEPT all -- 0.0.0.0/0 0.0.0.0/0
ACCEPT udp -- 0.0.0.0/0 0.0.0.0/0 udp dpt:1194
DROP all -- 0.0.0.0/0 0.0.0.0/0 state INVALID
ACCEPT all -- 0.0.0.0/0 0.0.0.0/0 state RELATED,ESTABLISHED
ACCEPT all -- 0.0.0.0/0 0.0.0.0/0 state NEW
ACCEPT udp -- 0.0.0.0/0 0.0.0.0/0 udp spt:67 dpt:68
ACCEPT tcp -- 0.0.0.0/0 192.168.0.1 tcp dpt:80
ACCEPT tcp -- 0.0.0.0/0 192.168.0.1 tcp dpt:8443
Chain FORWARD (policy DROP)
ipttolan all -- 0.0.0.0/0 0.0.0.0/0
iptfromlan all -- 0.0.0.0/0 0.0.0.0/0
PControls all -- 0.0.0.0/0 0.0.0.0/0 TIME on Sun,Mon,Tue,Wed,Thu MAC BC:67:7
PControls all -- 0.0.0.0/0 0.0.0.0/0 TIME to 3:0 on Fri MAC BC:67:
PControls all -- 0.0.0.0/0 0.0.0.0/0 TIME from 17:0 on Fri MAC BC
PControls all -- 0.0.0.0/0 0.0.0.0/0 TIME on Sat MAC BC:67
DROP all -- 0.0.0.0/0 0.0.0.0/0 MAC BC:67:78:
PControls all -- 0.0.0.0/0 0.0.0.0/0 TIME to 21:0 on Sun MAC 5C:FXXXX
PControls all -- 0.0.0.0/0 0.0.0.0/0 TIME from 6:0 to 21:0 on Mon MAC 5C:F9:3;ewd;w
PControls all -- 0.0.0.0/0 0.0.0.0/0 TIME from 6:0 to 21:0 on Tue MAC 5C:F9:38:66:5B:4D
PControls all -- 0.0.0.0/0 0.0.0.0/0 TIME from 6:0 to 21:0 on Wed MAC 5C:oepowje
PControls all -- 0.0.0.0/0 0.0.0.0/0 TIME from 6:0 to 21:0 on Thu MAC 5C:F9:3XXXX
PControls all -- 0.0.0.0/0 0.0.0.0/0 TIME from 6:0 to 23:0 on Fri MAC 5C:F9:3XXX
PControls all -- 0.0.0.0/0 0.0.0.0/0 TIME to 23:0 on Sat MAC 5C:F9:38:66:5B:4D
DROP all -- 0.0.0.0/0 0.0.0.0/0 MAC 5C:F9:38:66:5B:4D
PControls all -- 0.0.0.0/0 0.0.0.0/0 TIME to 21:0 on Sun MAC 5C:F9:38:3C:32:04
PControls all -- 0.0.0.0/0 0.0.0.0/0 TIME from 6:0 to 21:0 on Mon MAC 5C:F9:XXXXXXX
PControls all -- 0.0.0.0/0 0.0.0.0/0 TIME from 6:0 to 21:0 on Tue MAC 5C:F9:xxxxxx
PControls all -- 0.0.0.0/0 0.0.0.0/0 TIME from 6:0 to 21:0 on Wed MAC 5C:F9:38xxxxxx
PControls all -- 0.0.0.0/0 0.0.0.0/0 TIME to 23:0 on Sat MAC 5C: etc
DROP all -- 0.0.0.0/0 0.0.0.0/0 MAC 5C:F9:38:3C:32:04
PControls all -- 0.0.0.0/0 0.0.0.0/0 TIME on Sun,Mon,Tue,Wed,Thu MAC 14:99:E
PControls all -- 0.0.0.0/0 0.0.0.0/0 TIME to 3:0 on Fri MAC 14:99:
PControls all -- 0.0.0.0/0 0.0.0.0/0 TIME from 16:0 on Fri MAC 14:99:
PControls all -- 0.0.0.0/0 0.0.0.0/0 TIME on Sat MAC 14:99
DROP all -- 0.0.0.0/0 0.0.0.0/0 MAC 14:99:E2
TCPMSS tcp -- 0.0.0.0/0 0.0.0.0/0 tcp flags:0x06/0x02 TCPMSS clamp to PMTU
DROP icmp -- 0.0.0.0/0 0.0.0.0/0
ACCEPT all -- 0.0.0.0/0 0.0.0.0/0 ctstate DNAT
Chain OUTPUT (policy ACCEPT)
Chain FUPNP (0 references)
Chain PControls (22 references)
Chain iptfromlan (1 references)
RETURN all -- 0.0.0.0/0 0.0.0.0/0 account: network/netmask: 192.168.0.0/255.255.255.0 name: lan
Chain ipttolan (1 references)
Chain logaccept (0 references)
LOG all -- 0.0.0.0/0 0.0.0.0/0 state NEW LOG flags 7 level 4 prefix `ACCEPT '
Chain logdrop (0 references)
LOG all -- 0.0.0.0/0 0.0.0.0/0 state NEW LOG flags 7 level 4 prefix `DROP '
admin@RT-N66U:/tmp/etc/openvpn/server1#
Kernel IP routing table
Destination Gateway Genmask Flags Metric Ref Use Iface
195.10.125.x 0.0.0.0 255.255.255.255 UH 0 0 0 ppp0
10.8.0.2 0.0.0.0 255.255.255.255 UH 0 0 0 tun21
10.8.0.0 10.8.0.2 255.255.255.0 UG 0 0 0 tun21
192.168.0.0 0.0.0.0 255.255.255.0 U 0 0 0 br0
127.0.0.0 0.0.0.0 255.0.0.0 U 0 0 0 lo
0.0.0.0 195.10.125.83 0.0.0.0 UG 0 0 0 ppp0
Welcome To SNBForums
