OpenVPN Server
margentieri
I am having an issue in trying to run both OpenVPN servers at the same time. I am able to run server 1 or server 2 individually with no problem, but when one is already active and I attempt to activate the second, I receive the following error message in the "Export OpenVPN configuration file" field:
Starting the server...
OpenVPN server daemon start fail!
Please check your device environment or contents on advanced setting page.
I want to run both of these servers at the same time, as I have different access settings for each server. Is it possible to run both servers at the same time? Or am I just doing something wrong?
Thanks!
Make sure they use different ports or protocol. You cannot run two network services at the same time on the same port and with the same protocol (TCP or UDP).
Thank you! Duhhh, that should have been so obvious! Changed the port on one of the servers, and now everything is working great :D
