OpenVPN Simultaneous Multi Server Connections?
Wingsfan87
Background: I want to connect my home router VPN client option to 2 Open VPN servers simultaneously. Currently every time I try to Activate both the other deactivates and drops the connection. Is it possible to run both or Asus to add this ability to the next firmware update
Device: RT-AC5300
Firmware: 3.0.0.4.380_3941
Setup:
  • Both of the remote OpenVPN servers are also hosted on ASUS routers RT-AC68R's.
  • Each of the 3 networks have different subnets.
  • Both remote OpenVPN servers use different ports and different VPN subnets
  • Neither remote OpenVPN servers redirect internet traffic and do not respond to DNS all that is run local
  • I can connect fine to either one and do RPD, remote file share, access the router admin page or anything running via IP.
Preferred set up would be to have 1 Open VPN server hosted at the one office and have both my home and the other remote office connect to it and be able to access the remote office #2 (client) from my home (also a client). But this set up doesn't work as I can't access the other client. Even though the option is set for clients allowed to talk to one another.
So right now I have 2 Open VPN servers at the 2 separate offices and I want to be able to connect to both at the same time from my home router as the client.
Any ideas or help with either problem?
