skilledone
Greetings all,
I know this question has been asked before so I, of course, did some searching around threads to collect different things users have tried.
Right now I'm running an AC88U Router w/ a 1Gbit symmetrical connection. Firmware:380.66_4
I'm trying to figure out why my VPN speeds are so abysmal when I'm on a 150/150 connection when away from home. Speeds improved slightly when I changed some settings, so here are my current settings. If there is anything you think I should change, your input is welcomed. Prior to the below settings, I was getting below 1Mbps/1Mbps
. I just want at least 15/15, jeez, especially on my FAT pipe1
VPN Speed Test - http://www.speedtest.net/my-result/6371815475
Non VPN Speed Test - http://www.speedtest.net/my-result/6371824273
VPN Settings - Data encryption: AES-128
Data authentication: SHA1
Handshake: RSA-2048
LZO: Disabled
Custom Configuration Settings:
sndbuf 524288
rcvbuf 524288
push "sndbuf 524288"
push "rcvbuf 524288"
Handshake: RSA-2048
LZO: Disabled
sndbuf 524288
rcvbuf 524288
