Mistermoonlight
I was running an old merlin firmware (270.26) version and when i updated to version 50 beta 1, i have seen that the openvpn static key configuration is now gone in the gui. In the advance openvpn section, we can configure all keys, but not a static key anymore (it was there in older firmware). The problem is that i wanted to reuse the same exact openvpn setup with all exact same keys that i had. While i could not figure out in what linux file to change the key, i used the nvram backup tool (from another user's in the forum) to backup all the nvram settings and edit the openvpn static key that was in the backup, then i restored only the openvpn section to the nvram and this is the workaround i got back the previous openvpn static key i was using.
