Sat Dec 27 15:28:47 2014 us=79620 OpenVPN 2.3.6 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [PKCS11] [IPv6] built on Dec 1 2014
Sat Dec 27 15:28:47 2014 us=79620 library versions: OpenSSL 1.0.1j 15 Oct 2014, LZO 2.08
Enter Management Password:
Sat Dec 27 15:28:47 2014 us=80620 MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:25340
Sat Dec 27 15:28:47 2014 us=80620 Need hold release from management interface, waiting...
Sat Dec 27 15:28:47 2014 us=482643 MANAGEMENT: Client connected from [AF_INET]127.0.0.1:25340
Sat Dec 27 15:28:47 2014 us=582649 MANAGEMENT: CMD 'state on'
Sat Dec 27 15:28:47 2014 us=582649 MANAGEMENT: CMD 'log all on'
Sat Dec 27 15:28:51 2014 us=933898 MANAGEMENT: CMD 'hold off'
Sat Dec 27 15:28:51 2014 us=972900 MANAGEMENT: CMD 'hold release'
Sat Dec 27 15:28:52 2014 us=222915 LZO compression initialized
Sat Dec 27 15:28:52 2014 us=222915 Control Channel MTU parms [ L:1560 D:140 EF:40 EB:0 ET:0 EL:0 ]
Sat Dec 27 15:28:52 2014 us=222915 Socket Buffers: R=[8192->8192] S=[8192->8192]
Sat Dec 27 15:28:52 2014 us=223915 MANAGEMENT: >STATE:1419712132,RESOLVE,,,
Sat Dec 27 15:28:52 2014 us=262917 Data Channel MTU parms [ L:1560 D:1450 EF:60 EB:135 ET:0 EL:0 AF:3/1 ]
Sat Dec 27 15:28:52 2014 us=262917 Local Options String: 'V4,dev-type tun,link-mtu 1560,tun-mtu 1500,proto TCPv4_CLIENT,comp-lzo,cipher AES-128-CBC,auth SHA1,keysize 128,key-method 2,tls-client'
Sat Dec 27 15:28:52 2014 us=262917 Expected Remote Options String: 'V4,dev-type tun,link-mtu 1560,tun-mtu 1500,proto TCPv4_SERVER,comp-lzo,cipher AES-128-CBC,auth SHA1,keysize 128,key-method 2,tls-server'
Sat Dec 27 15:28:52 2014 us=262917 Local Options hash (VER=V4): 'bc07730e'
Sat Dec 27 15:28:52 2014 us=262917 Expected Remote Options hash (VER=V4): 'b695cb4a'
Sat Dec 27 15:28:52 2014 us=262917 Attempting to establish TCP connection with [AF_INET]70.61.70.126:1194 [nonblock]
Sat Dec 27 15:28:52 2014 us=262917 MANAGEMENT: >STATE:1419712132,TCP_CONNECT,,,
Sat Dec 27 15:29:02 2014 us=273489 TCP: connect to [AF_INET]70.61.70.126:1194 failed, will try again in 5 seconds: The system tried to join a drive to a directory on a joined drive.
Sat Dec 27 15:29:02 2014 us=277490 SIGUSR1[soft,init_instance] received, process restarting
Sat Dec 27 15:29:02 2014 us=279490 MANAGEMENT: >STATE:1419712142,RECONNECTING,init_instance,,
Sat Dec 27 15:29:02 2014 us=279490 Restart pause, 5 second(s)
Sat Dec 27 15:29:07 2014 us=279776 Re-using SSL/TLS context
Sat Dec 27 15:29:07 2014 us=279776 LZO compression initialized
Sat Dec 27 15:29:07 2014 us=280776 Control Channel MTU parms [ L:1560 D:140 EF:40 EB:0 ET:0 EL:0 ]
Sat Dec 27 15:29:07 2014 us=280776 Socket Buffers: R=[8192->8192] S=[8192->8192]
Sat Dec 27 15:29:07 2014 us=280776 Data Channel MTU parms [ L:1560 D:1450 EF:60 EB:135 ET:0 EL:0 AF:3/1 ]
Sat Dec 27 15:29:07 2014 us=280776 Local Options String: 'V4,dev-type tun,link-mtu 1560,tun-mtu 1500,proto TCPv4_CLIENT,comp-lzo,cipher AES-128-CBC,auth SHA1,keysize 128,key-method 2,tls-client'
Sat Dec 27 15:29:07 2014 us=280776 Expected Remote Options String: 'V4,dev-type tun,link-mtu 1560,tun-mtu 1500,proto TCPv4_SERVER,comp-lzo,cipher AES-128-CBC,auth SHA1,keysize 128,key-method 2,tls-server'
Sat Dec 27 15:29:07 2014 us=281776 Local Options hash (VER=V4): 'bc07730e'
Sat Dec 27 15:29:07 2014 us=281776 Expected Remote Options hash (VER=V4): 'b695cb4a'
Sat Dec 27 15:29:07 2014 us=281776 Attempting to establish TCP connection with [AF_INET]70.61.70.126:1194 [nonblock]
Sat Dec 27 15:29:07 2014 us=281776 MANAGEMENT: >STATE:1419712147,TCP_CONNECT,,,
Sat Dec 27 15:29:17 2014 us=286348 TCP: connect to [AF_INET]70.61.70.126:1194 failed, will try again in 5 seconds: The system tried to join a drive to a directory on a joined drive.
Sat Dec 27 15:29:17 2014 us=286348 SIGUSR1[soft,init_instance] received, process restarting
Sat Dec 27 15:29:17 2014 us=287348 MANAGEMENT: >STATE:1419712157,RECONNECTING,init_instance,,
Sat Dec 27 15:29:17 2014 us=287348 Restart pause, 5 second(s)
Sat Dec 27 15:29:18 2014 us=287405 SIGTERM[hard,init_instance] received, process exiting
Sat Dec 27 15:29:18 2014 us=287405 MANAGEMENT: >STATE:1419712158,EXITING,init_instance,,
