OpenVPN TLS timeouts
Zac F
Out of curiosity how long should the TLS take to timeout? I've been unable to connect any of my android devices to VPN because TLS keeps timing out. Here's the log entries:
Aug  8 10:12:37 openvpn[1541]: 192.168.0.103:52521 TLS: Initial packet from [AF_INET]192.168.0.103:52521, sid=422a29cb 75c7d516
Aug  8 10:12:47 openvpn[1541]: 192.168.0.103:58808 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Aug  8 10:12:47 openvpn[1541]: 192.168.0.103:58808 TLS Error: TLS handshake failed
Aug  8 10:12:47 openvpn[1541]: 192.168.0.103:58808 SIGUSR1[soft,tls-error] received, client-instance restarting
Aug  8 10:12:51 openvpn[1541]: 192.168.0.103:58575 TLS: Initial packet from [AF_INET]192.168.0.103:58575, sid=436b59f7 5b7749f6
Aug  8 10:12:57 openvpn[1541]: 192.168.0.103:33609 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Aug  8 10:12:57 openvpn[1541]: 192.168.0.103:33609 TLS Error: TLS handshake failed
Aug  8 10:12:57 openvpn[1541]: 192.168.0.103:33609 SIGUSR1[soft,tls-error] received, client-instance restarting
Aug  8 10:13:00 openvpn[1541]: 192.168.0.103:50572 TLS: Initial packet from [AF_INET]192.168.0.103:50572, sid=a0d133cb db91db44
Aug  8 10:13:07 openvpn[1541]: 192.168.0.103:39690 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Aug  8 10:13:07 openvpn[1541]: 192.168.0.103:39690 TLS Error: TLS handshake failed
Aug  8 10:13:07 openvpn[1541]: 192.168.0.103:39690 SIGUSR1[soft,tls-error] received, client-instance restarting
Aug  8 10:13:10 openvpn[1541]: 192.168.0.103:36061 TLS: Initial packet from [AF_INET]192.168.0.103:36061, sid=fdfa3bfe e6bb1bff
Aug  8 10:13:17 openvpn[1541]: 192.168.0.103:35989 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Aug  8 10:13:17 openvpn[1541]: 192.168.0.103:35989 TLS Error: TLS handshake failed
This specific block of logs was from my tablet on WiFi, but I get the same behavior on 4G with my phone. I did have the phone connect up last night after trying 6 times, so something seems a little wonky. Thoughts?
Thanks!
i see in my syslog same errors.....this happens mostly between first and second hour runing OpenVPN?
Aug 23 11:20:20 openvpn[8306]: xxxxx/xxx.xxx.xxx.xxx:39082 TLS: soft reset sec=0 bytes=30491417/0 pkts=36936/0
Aug 23 11:20:21 openvpn[8306]: xxxxx/xxx.xxx.xxx.xxx:39082 TLS ERROR: local/remote key IDs out of sync (2/3) ID:  [key#0 state=S_START id=2 sid=dcff5fe0 f2b8cc0b] [key#1 state=S_NORMAL_OP id=1 sid=dcff5fe0 f2b8cc0b] [key#2 state=S_UNDEF id=0 sid=00000000 00000000]
Aug 23 11:20:23 openvpn[8306]: xxxxx/xxx.xxx.xxx.xxx:39082 TLS ERROR: local/remote key IDs out of sync (2/3) ID:  [key#0 state=S_START id=2 sid=dcff5fe0 f2b8cc0b] [key#1 state=S_NORMAL_OP id=1 sid=dcff5fe0 f2b8cc0b] [key#2 state=S_UNDEF id=0 sid=00000000 00000000]
Aug 23 11:20:26 openvpn[8306]: xxxxx/xxx.xxx.xxx.xxx:39082 TLS ERROR: local/remote key IDs out of sync (2/3) ID:  [key#0 state=S_START id=2 sid=dcff5fe0 f2b8cc0b] [key#1 state=S_NORMAL_OP id=1 sid=dcff5fe0 f2b8cc0b] [key#2 state=S_UNDEF id=0 sid=00000000 00000000]
Aug 23 11:20:27 openvpn[8306]: xxxxx/xxx.xxx.xxx.xxx:39082 TLS ERROR: local/remote key IDs out of sync (2/3) ID:  [key#0 state=S_START id=2 sid=dcff5fe0 f2b8cc0b] [key#1 state=S_NORMAL_OP id=1 sid=dcff5fe0 f2b8cc0b] [key#2 state=S_UNDEF id=0 sid=00000000 00000000]
Aug 23 11:20:30 openvpn[8306]: xxxxx/xxx.xxx.xxx.xxx:39082 TLS ERROR: local/remote key IDs out of sync (2/3) ID:  [key#0 state=S_START id=2 sid=dcff5fe0 f2b8cc0b] [key#1 state=S_NORMAL_OP id=1 sid=dcff5fe0 f2b8cc0b] [key#2 state=S_UNDEF id=0 sid=00000000 00000000]
Aug 23 11:20:35 openvpn[8306]: xxxxx/xxx.xxx.xxx.xxx:39082 TLS ERROR: local/remote key IDs out of sync (2/3) ID:  [key#0 state=S_START id=2 sid=dcff5fe0 f2b8cc0b] [key#1 state=S_NORMAL_OP id=1 sid=dcff5fe0 f2b8cc0b] [key#2 state=S_UNDEF id=0 sid=00000000 00000000]
Aug 23 11:20:37 openvpn[8306]: xxxxx/xxx.xxx.xxx.xxx:39082 TLS ERROR: local/remote key IDs out of sync (2/3) ID:  [key#0 state=S_START id=2 sid=dcff5fe0 f2b8cc0b] [key#1 state=S_NORMAL_OP id=1 sid=dcff5fe0 f2b8cc0b] [key#2 state=S_UNDEF id=0 sid=00000000 00000000]
Aug 23 11:20:53 openvpn[8306]: xxxxx/xxx.xxx.xxx.xxx:39082 TLS ERROR: local/remote key IDs out of sync (2/3) ID:  [key#0 state=S_START id=2 sid=dcff5fe0 f2b8cc0b] [key#1 state=S_NORMAL_OP id=1 sid=dcff5fe0 f2b8cc0b] [key#2 state=S_UNDEF id=0 sid=00000000 00000000]
Aug 23 11:21:09 openvpn[8306]: xxxxx/xxx.xxx.xxx.xxx:39082 TLS ERROR: local/remote key IDs out of sync (2/3) ID:  [key#0 state=S_START id=2 sid=dcff5fe0 f2b8cc0b] [key#1 state=S_NORMAL_OP id=1 sid=dcff5fe0 f2b8cc0b] [key#2 state=S_UNDEF id=0 sid=00000000 00000000]
Aug 23 11:21:21 openvpn[8306]: xxxxx/xxx.xxx.xxx.xxx:39082 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Aug 23 11:21:21 openvpn[8306]: xxxxx/xxx.xxx.xxx.xxx:39082 TLS Error: TLS handshake failed
Aug 23 11:21:21 openvpn[8306]: xxxxx/xxx.xxx.xxx.xxx:39082 TLS: move_session: dest=TM_LAME_DUCK src=TM_ACTIVE reinit_src=1
Aug 23 11:21:24 openvpn[8306]: xxxxx/xxx.xxx.xxx.xxx:39082 TLS ERROR: received control packet with stale session-id=dcff5fe0 f2b8cc0b
Aug 23 11:21:38 openvpn[8306]: xxxxx/xxx.xxx.xxx.xxx:39082 TLS ERROR: received control packet with stale session-id=dcff5fe0 f2b8cc0b
Aug 23 11:21:42 openvpn[8306]: xxxxx/xxx.xxx.xxx.xxx:39082 TLS ERROR: received control packet with stale session-id=dcff5fe0 f2b8cc0b
Aug 23 11:21:51 openvpn[8306]: xxxxx/xxx.xxx.xxx.xxx:39082 TLS ERROR: received control packet with stale session-id=dcff5fe0 f2b8cc0b
Aug 23 11:22:06 openvpn[8306]: xxxxx/xxx.xxx.xxx.xxx:39082 TLS ERROR: received control packet with stale session-id=dcff5fe0 f2b8cc0b
Aug 23 11:22:12 openvpn[8306]: xxxxx/xxx.xxx.xxx.xxx:39082 TLS ERROR: received control packet with stale session-id=dcff5fe0 f2b8cc0b
Aug 23 11:22:21 openvpn[8306]: xxxxx/xxx.xxx.xxx.xxx:39082 TLS ERROR: received control packet with stale session-id=dcff5fe0 f2b8cc0b
Aug 23 11:22:36 openvpn[8306]: xxxxx/xxx.xxx.xxx.xxx:39082 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Aug 23 11:22:36 openvpn[8306]: xxxxx/xxx.xxx.xxx.xxx:39082 TLS Error: TLS handshake failed
Thanks!
That's is probably "Extra HMAC Authorization (tls-auth)" direction. Client should be 1 and server 0.
Android have problem with Mashmallow and openvpn client.
You must defind your DNS in your phone and turn off powersavings to get it to work.
Bayern1975 don't hijack others threads for your own purposes!
Bayern1975 don't hijack others thread for your own purposes!
no, i did not hijacked the thread because i have identical errors then member @Zac F.....so i need info what and where have to change something to working without that TLS errors.....:)
Why don't you have make your own thread with that question, i have seen it before.
