Hello,
I am looking to share the same subnet of my LAN network with my VPN devices. The reason being, my Netgear Arlo Ultra cameras would not stream in high resolution unless you are on the same local network, VPN would not work either and according to this post, it is possible to fool Arlo if you put VPN devices on the same subnet.
My devices:
Router: RT-AC88U
Router Firmware: 383.13
Mobile Device: iPhone 11Pro
VPN: OpenVPN TUN
Just to clarify, I have tried exploring PPTP and IPsec VPNs, PPTP is not supported by iPhones and IPsec doesn’t seem to have options to specify subnet information in the configurations. OpenVPN TAP looks like it will do the job easily but it is not supported by iPhones anymore. Looks like the only option I have left is OpenVPN TUN (please let me know if there’s a better option).
What I did was, first (first screenshot) I split the subnet into two and assigned 192.168.1.1-126 to LAN devices in the DHCP server on the router. Then in the VPN > OpenVPN > advanced settings page, I tried using VPN subnet (192.168.1.200) / Netmask (255.255.255.252) but I am getting error (second screenshot) “Conflict with the router’s DHCP IP pool: 192.168.1.2-192.168.1.126”.
Can someone please advise? I have a bit of knowledge but definitely not very good, apologies if I missed any important information.
Thanks,
Jeffrey
My devices:
Router: RT-AC88U
VPN: OpenVPN TUN
Thanks,
Jeffrey
