I use Tunnelblick on macOS as my OpenVPN client. Recently when I connect to my Asus AC68 Router with Asuswrt-Merlin V384.4 I get the following message:
Hopefully there is a planned update to the OpenVPN server to v2.5 for Asus-wrt Merlin or am I missing something?
Thank you for your help.
Warning: This VPN may not connect in the future.
The OpenVPN configuration file for 'xxxx' contains these OpenVPN options:
'comp-lzo' was deprecated in OpenVPN 2.4 and removed in OpenVPN 2.5
'ns-cert-type' was deprecated in OpenVPN 2.4 and removed in OpenVPN 2.5
You should update the configuration so it can be used with modern versions of OpenVPN.
Tunnelblick will use OpenVPN 2.4.4 - OpenSSL v1.0.2n to connect this configuration.
However, you will not be able to connect to this VPN with future versions of Tunnelblick that do not include a version of OpenVPN that accepts the options.
