/opt/bin/ld: cannot find -lsqlite3 (trying to compile asterisk-11)
Martin - SNBuser
Hi all,
I don't know what has happened, but I'm a happy user of entware so once in a while I "opkg update/upgrade" and now asterisk doesn't work anymore. Nothing I tried worked anymore, so I figured, maybe I should try to compile my first entware/asterisk program. I configure like this:
$ ./configure --prefix=/opt --disable-xmldoc --with-sqlite3=/usr/lib
## Platform. ##
hostname = router
uname -m = armv7l
uname -r = 2.6.36.4brcmarm
uname -s = Linux
uname -v = #2 SMP PREEMPT Sun Apr 8 14:14:38 EDT 2018
COLLECT_GCC=gcc
COLLECT_LTO_WRAPPER=/tmp/mnt/entwareCIFS/entware/bin/../lib/gcc/arm-openwrt-linux-gnueabi/6.3.0/lto-wrapper
Target: arm-openwrt-linux-gnueabi
Configured with: /media/ware3/Entware.2018.05/build_dir/target-arm_cortex-a9_glibc-2.23_eabi/gcc-6.3.0/configure --target=arm-openwrt-linux --host=arm-openwrt-linux --build=x86_64-pc-linux-gnu --program-prefix= --program-suffix= --prefix=/opt --exec-prefix=/opt --bindir=/opt/bin --sbindir=/opt/sbin --libexecdir=/opt/lib --sysconfdir=/opt/etc --datadir=/opt/share --localstatedir=/opt/var --mandir=/opt/man --infodir=/opt/info --disable-nls --build=x86_64-pc-linux-gnu --host=arm-openwrt-linux-gnueabi --target=arm-openwrt-linux-gnueabi --enable-languages=c,c++ --with-bugurl=https://dev.openwrt.org/ --with-pkgversion='OpenWrt GCC 6.3.0' --enable-shared --enable-__cxa_atexit --with-default-libstdcxx-abi=gcc4-compatible --enable-target-optspace --with-gnu-ld --with-stage1-ldflags='-Wl,-rpath=/opt/lib -Wl,--dynamic-linker=/opt/lib/ld-linux.so.3' --with-specs='-Wl,-rpath=/opt/lib -Wl,--dynamic-linker=/opt/lib/ld-linux.so.3' --with-boot-ldflags='static-libstdc++ -static-libgcc -Wl,-rpath=/opt/lib -Wl,--dynamic-linker=/opt/lib/ld-linux.so.3' --disable-nls --disable-libsanitizer --disable-libvtv --disable-libcilkrts --disable-libmudflap --disable-multilib --disable-libgomp --disable-libquadmath --disable-libssp --disable-decimal-float --disable-libstdcxx-pch --with-host-libstdcxx=-lstdc++ --prefix=/opt --libexecdir=/opt/lib --with-local-prefix=/opt --with-float=soft --with-default-libstdcxx-abi=gcc4-compatible
Thread model: posix
gcc version 6.3.0 (OpenWrt GCC 6.3.0)
COMPILER_PATH=/tmp/mnt/entwareCIFS/entware/bin/../lib/gcc/arm-openwrt-linux-gnueabi/6.3.0/:/tmp/mnt/entwareCIFS/entware/bin/../lib/gcc/
LIBRARY_PATH=/tmp/mnt/entwareCIFS/entware/bin/../lib/gcc/arm-openwrt-linux-gnueabi/6.3.0/:/tmp/mnt/entwareCIFS/entware/bin/../lib/gcc/:/tmp/mnt/entwareCIFS/entware/bin/../lib/gcc/arm-openwrt-linux-gnueabi/6.3.0/../../../:/lib/:/usr/lib/
checking for speex_encode in -lspeex... no
checking for speex_preprocess_ctl in -lspeex... no
checking for speex_preprocess_ctl in -lspeexdsp... no
checking for sqlite_exec in -lsqlite... no
checking for sqlite3_open in -lsqlite3... no
configure: error: *** Asterisk now uses SQLite3 for the internal Asterisk database.
It ends up complaining about sqlite3 and drops back to the terminal prompt, which I don't understand. opkg list reveals that I need to install libsqlite3, but I already seem to have this I think (and now I cannot insert the code I wanted, a message constantly pops up and says I'm blocked and something cloudflare I think - so I've copy/pasted what I tried here: https://pastebin.com/W6WepNC6 )
The last thing I tried (https://pastebin.com/W6WepNC6) didn't work... So, could anyone please help with a few suggestions/hints as to how to get going with sqlite3?
I would be very grateful if you could help a bit and help me solve this problem, if I succeed, this would be the first time for me to compile a program on my router? :-)
