/opt folder link
Rooby
Hello
I have two identical routers and I have configured them for optware with installing the download master.
But the the /opt folder link chains are different:
On one router the /opt folder links to
/opt -> /tmp/opt -> /tmp/mnt/DISK/asusware
(DISK is my usb disk name)
This seems to me correct.
The other router it is
/opt -> tmp/opt
and in the tmp/opt folder some subfolders are link to /tmp/mnt/DISK/asusware/..
The problem I have is that on that router the /opt/lib folder is not linked to
/tmp/mnt/DISK/asusware/lib
If I then install a package with ipkg then the installed libraries get lost after rebooting since ther are not stored on the USB.
Does someone know what is correct?
I just want to mention that the problem was that the USB stick was FAT32 formatted.
I reformatted it to NTFS and it is working now.
The /opt folder links now to
which is working ok.
So do not use FAT32 for the USB stick.
