AFAIK, the Xbox wifi chip has some issues (bugs) that make it problematic in certain environments so the xbox setting does something (what, i don't know) to make it more compatible with the xbox.
Technically, that option makes the router report it does not support LDPC error correction.
Any idea on why having it on makes the wireless more stable for all of my wireless devices?
So if our Xbox One is connected to our 5.0GHz network, we should check "Optimized for Xbox?"
I believe this is only in relation to the 360.
Seems like nobody has a concrete answer on what this setting does or applies to.
Merlin has said what this setting does in this thread.
In a roundabout way it fixes a compatibility issue between the 360 S' wireless driver and the Asus firmware.
I have no idea.
LDPC is an optional mode for the 802.11N and AC standards. In simple terms, is helps correct for high Signal To Noise environments, like when lots of 802.11 networks exist together or you have a microwave oven creating interference.
http://demoui.asus.com:8085/Advanced_Wireless_Content.aspJust curious, is this an official Asus firmware setting or a Merlin setting
Welcome To SNBForums
