Hello, hoping someone can help me out
I have an AiMesh system that consists of Blue Cave, AC1900 and recently an RP-AX56. Im running a Gibabit Ethernet connection and with the mesh nodes wired.
My problem is that the iPhones in the family have substantially worse reception on the wifi network than my Samsung (all rather new devices). In the Kitchen for example I can get 700mbs on Speedtest but iPhone barely gets to 60-70mbs.
I have tried to analyse the network signal in the house and adjusted the Roaming Assistant accordingly. But the iPhones usually are stuck on the first node they connect to. For example the iphone is still on a weaker signal when on the first floor as it is connected to the main router on the second floor even though the signal is below the roaming assistant value.
Anyone have any suggestions? I have tried to disable Smart Connect etc..
Regards,
Bez
Regards,
Bez
