lan
tag did not apply, but a br0
tag had to be added for the ULA range. Specific details (and my memory) are sketchy, but I ultimately dropped the idea.And if you set DHCP-PD to Disabled you get to put in your own ip for br0, which could be a ULA If so wishes. It wouldn't work for internet (unless firewall rules for ipv6 nat is added) but that's another story.What is the use case here? If you enable IPv6 on the WAN then the bridge interface already gets a link local IPv6 address (IIRC).
Welcome To SNBForums
