optware + vpnc possible?
Eet_46
Hi! I'm new here and i'm quite new to the router flashing world in general, so i was hoping for some good advice :)
I've been posting on the dd-wrt and tomato forums aswell, but i'm still not there yet...
I have an Asus RT-AC56U, which i'm trying to get connected to a cisco vpn provider, which uses the ipsec protocol with xauth..
This means i need vpnc running and would then be running a startup script, to establish the vpn connection.
My question is, is it possible to install optware (i've seen a quick tutorial for the AC68U, so i guess it applies to the AC56U aswell), then vpnc and run the connection script on Merlin firmware?
Right now i'm on dd-wrt (no vpnc in any builds for my router it seems), but i'm stuck on installing optware, ipkg won't update - repository doesn't exist..
Thanks!
EDIT:
I THINK i managed to get vpnc installed, i'm about to test it out :)
But that brings me to next question.. I need to run a connection script, which i have to put on the jffs partition as i understand..
So, i created a script in the /jffs/scripts folder, but what should it be called? If i understand correctly, i need to name it after when the script must be run, my guess would be init-start for this script?? But i have no clue what would make it work..
Here's the script:
mkdir -p /tmp/etc/vpnc
rm -f /tmp/etc/vpnc/vpnc.sh
echo '
#!/bin/sh
vpn_concentrator="signon1.beevpn.com"
vpn_keepalive_host1="217.15.175.65"
vpn_groupname="beevpn"
vpn_grouppasswd="beecustomer"
vpn_username="" ##enter your username here
vpn_password="" ##enter your password here
#--do not edit this--
#Written by Alain R. 28.Sep.2007, and fixed/adapted by BeeVPN 13.May.2012
vpnc-disconnect
rm -f /tmp/etc/vpnc/vpn.conf
echo "
IPSec gateway $vpn_concentrator
IPSec ID $vpn_groupname
IPSec secret $vpn_grouppasswd
Xauth username $vpn_username
Xauth password $vpn_password
" >> /tmp/etc/vpnc/vpn.conf
DEFAULT_ROUTE_BACKUP="/tmp/vpnc-default-route-backup"
DEFAULT_RESOLV_BACKUP="/tmp/vpnc-default-resolv-backup"
pingtest1 () {
ping -w 5 -q -c2 $param1 >> /dev/null
if [ "$?" == "0" ]; then
echo 0 #reachable
else
echo 1 #not reachable
fi
iptablesdone="0"
restore_routing() {
if [ -f $DEFAULT_ROUTE_BACKUP ]; then
if [ "`ip route |grep default`" == "" ]; then
ip route add `cat "$DEFAULT_ROUTE_BACKUP"`
else
ip route replace `cat "$DEFAULT_ROUTE_BACKUP"`
fi
fi
restore_everything() {
tundev="`ifconfig |grep tun |cut -b 1-4`"
vpnc-disconnect
restore_routing
if [ "$iptablesdone" == "1" ]; then
iptables -D FORWARD -o $tundev -j ACCEPT
iptables -D FORWARD -i $tundev -j ACCEPT
iptables -t nat -D POSTROUTING -o $tundev -j MASQUERADE
iptablesone="0";
fi
if [ -f $DEFAULT_RESOLV_BACKUP ]; then
cat $DEFAULT_RESOLV_BACKUP > /tmp/etc/vpnc/resolv.dnsmasq.tmp
killall dnsmasq
cat /tmp/etc/vpnc/resolv.dnsmasq.tmp > /tmp/resolv.dnsmasq
dnsmasq --conf-file=/tmp/dnsmasq.conf
fi
if [ ! -f $DEFAULT_ROUTE_BACKUP ]; then
rm $DEFAULT_ROUTE_BACKUP
ip route| grep ^default > $DEFAULT_ROUTE_BACKUP
fi
if [ ! -f $DEFAULT_RESOLV_BACKUP ]; then
cp /etc/resolv.conf $DEFAULT_RESOLV_BACKUP
fi
while [ true ]; do
param1=$vpn_concentrator;
if [ "`pingtest1`" == "0" ]; then
doloop=1;
while [ $doloop -gt 0 ]; do
param1=$vpn_keepalive_host1;
sleep 300
else
doloop=0;
vpnc-disconnect
restore_everything
vpnc /tmp/etc/vpnc/vpn.conf --dpd-idle 0
sleep 1
if [ "`pingtest1`" != "0" ]; then
sleep 10
fi
if [ "$iptablesdone" == "0" ]; then
iptables -A FORWARD -o $tundev -j ACCEPT
iptables -A FORWARD -i $tundev -j ACCEPT
iptables -t nat -A POSTROUTING -o $tundev -j MASQUERADE
iptablesone="1";
fi
cat /tmp/resolv.conf > /tmp/etc/vpnc/resolv.dnsmasq.tmp
killall dnsmasq
sleep 9
fi
done
else
restore_routing
sleep 10;
fi
done
return 0;
' >> /tmp/etc/vpnc/vpnc.sh
chmod a+rx /tmp/etc/vpnc/vpnc.sh
sh /tmp/etc/vpnc/vpnc.sh&
