StreamBlank
Just changed from a Netgear RAX70 to Asus RT-AX88U Pro which I find much better, also went to Merlin as I had it on my previous Asus router.
There's only one thing I cant get to function which is my TV decoder via Wifi with my provider which is Orange in France.
In the french orange user forums people seem to constantly repeat that it won't work over wifi and it should not be done anyway but I managed to make it work on the netgear by using a vlan bridge.
Tried different combinations using IPTV settings but none worked
I kinda understand that I need to have those 3 VLANs go thru the router and directly unto my orange internet box
Channel 1: VLAN 840
VOD: VLAN 832
Zapping: VLAN 840
Is there a configuration page that I need to use to achieve that ? Should I write a script to enable it ? if yes, which ?
Thanks for any advice you my have!
Channel 1: VLAN 840
VOD: VLAN 832
Zapping: VLAN 840
