Entware Orbi New to Entware need help with alot
TanTheBananaMan
Hi there so I recently got Voxel on my orbi RBK50 and I have tried to install Entware but I am so confused and have spent so long trying to figure this out but no luck. So firstly I formatted a USB I have to EXT4 with DiskGenius because I don't know another way on how to format the drive then I plugged it into my orbi router and ran the command "mkfs.ext4 -L optware -O ^64bit /dev/sda1" on telnet with putty. I then get a message saying proceed (y,N) I enter y to proceed but nothing happens. Also, I cannot seem to use SSH with putty because whenever I put the correct password it crashes for some reason. I don't know if I am using the wrong program for this or I am just not doing it right but I would really appreciate it if someone could help me
Also this is the message PuTTY gives me after I type in my WebGUI password to login
If you have @kamoj add-on installed...
Q: How do I install Entware?
A: Run the kamoj add-on installation procedure: entware_install.sh
That script is what I used to install Entware on my R7800 device in router mode with a USB thumb drive. Please see the add-on documentation for additional information.
No I do not have the Kamoj add-on where can I get it?
