Hi, I have an ASUS AX86U running Merlin, with OVPN server enabled. My Android phone connects fine remotely.
I just gave an older AC68U running dd-wrt to an uncle who is traveling and would benefit from being able to tunnel through my home connection, so I set it up as a client and verified it worked (from within my house, therefore hairpinning from my own LAN) before handing it off to him.
Now when he plugs it in to his remote connection (currently an airbnb, either using or, I think, bypassing that location's router), it connects most of the way but fails at the "TLS key negotiation" stage, which from what I can tell from copious threads, is typically a server-side problem. This is surprising because (a) it works for my phone and (b) the server router is direct on my home fiber connection, there's no firewall in front and it doesn't seem like I need to manually forward ports to itself. Could it be a client-side problem, like he's actually going through another router there that could block it at this step?
Any suggestions? I'd really like to solve this on my server-side only if possible, so I don't have to walk my uncle through connecting to the client's router config page and making changes.
Thanks!
Thanks!
Jul 1 20:17:46 ovpn-server1[14651]: aaa.bbb.ccc.ddd:33540 TLS: Initial packet from [AF_INET]aaa.bbb.ccc.ddd:33540 (via [AF_INET]w.x.y.z%eth0), sid=75891fcb d3044d1b
Jul 1 20:17:46 ovpn-server1[14651]: aaa.bbb.ccc.ddd:33540 VERIFY OK: depth=1, C=TW, ST=TW, L=Taipei, O=ASUS, OU=Home/Office, CN=RT-AX86U, emailAddress=me@asusrouter.lan
Jul 1 20:17:46 ovpn-server1[14651]: aaa.bbb.ccc.ddd:33540 VERIFY OK: depth=0, C=TW, ST=TW, L=Taipei, O=ASUS, OU=Home/Office, CN=client, emailAddress=me@asusrouter.lan
Jul 1 20:17:46 ovpn-server1[14651]: aaa.bbb.ccc.ddd:33540 peer info: IV_VER=2.5.7
Jul 1 20:17:46 ovpn-server1[14651]: aaa.bbb.ccc.ddd:33540 peer info: IV_PLAT=linux
Jul 1 20:17:46 ovpn-server1[14651]: aaa.bbb.ccc.ddd:33540 peer info: IV_PROTO=6
Jul 1 20:17:46 ovpn-server1[14651]: aaa.bbb.ccc.ddd:33540 peer info: IV_NCP=2
Jul 1 20:17:46 ovpn-server1[14651]: aaa.bbb.ccc.ddd:33540 peer info: IV_CIPHERS=AES-256-GCM:AES-128-GCM:AES-256-CBC
Jul 1 20:17:46 ovpn-server1[14651]: aaa.bbb.ccc.ddd:33540 peer info: IV_LZ4=1
Jul 1 20:17:46 ovpn-server1[14651]: aaa.bbb.ccc.ddd:33540 peer info: IV_LZ4v2=1
Jul 1 20:17:46 ovpn-server1[14651]: aaa.bbb.ccc.ddd:33540 peer info: IV_LZO=1
Jul 1 20:17:46 ovpn-server1[14651]: aaa.bbb.ccc.ddd:33540 peer info: IV_COMP_STUB=1
Jul 1 20:17:46 ovpn-server1[14651]: aaa.bbb.ccc.ddd:33540 peer info: IV_COMP_STUBv2=1
Jul 1 20:17:46 ovpn-server1[14651]: aaa.bbb.ccc.ddd:33540 peer info: IV_TCPNL=1
Jul 1 20:17:46 ovpn-server1[14651]: aaa.bbb.ccc.ddd:33540 PLUGIN_CALL: POST /usr/lib/openvpn-plugin-auth-pam.so/PLUGIN_AUTH_USER_PASS_VERIFY status=0
Jul 1 20:17:46 ovpn-server1[14651]: aaa.bbb.ccc.ddd:33540 TLS: Username/Password authentication succeeded for username 'Remote'
Jul 1 20:17:46 ovpn-server1[14651]: aaa.bbb.ccc.ddd:33540 WARNING: 'link-mtu' is used inconsistently, local='link-mtu 1601', remote='link-mtu 1549'
Jul 1 20:17:46 ovpn-server1[14651]: aaa.bbb.ccc.ddd:33540 WARNING: 'auth' is used inconsistently, local='auth SHA512', remote='auth [null-digest]'
Jul 1 20:17:46 ovpn-server1[14651]: aaa.bbb.ccc.ddd:33540 Control Channel: TLSv1.3, cipher TLSv1.3 TLS_AES_256_GCM_SHA384, peer certificate: 1024 bit RSA, signature: RSA-SHA1
Jul 1 20:17:46 ovpn-server1[14651]: aaa.bbb.ccc.ddd:33540 [client] Peer Connection Initiated with [AF_INET]aaa.bbb.ccc.ddd:33540 (via [AF_INET]w.x.y.z%eth0)
Jul 1 20:17:46 ovpn-server1[14651]: client/aaa.bbb.ccc.ddd:33540 MULTI_sva: pool returned IPv4=10.8.0.2, IPv6=(Not enabled)
Jul 1 20:17:46 ovpn-server1[14651]: client/aaa.bbb.ccc.ddd:33540 MULTI: Learn: 10.8.0.2 -> client/aaa.bbb.ccc.ddd:33540
Jul 1 20:17:46 ovpn-server1[14651]: client/aaa.bbb.ccc.ddd:33540 MULTI: primary virtual IP for client/aaa.bbb.ccc.ddd:33540: 10.8.0.2
Jul 1 20:17:46 ovpn-server1[14651]: client/aaa.bbb.ccc.ddd:33540 Data Channel: using negotiated cipher 'AES-256-GCM'
Jul 1 20:17:46 ovpn-server1[14651]: client/aaa.bbb.ccc.ddd:33540 Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
Jul 1 20:17:46 ovpn-server1[14651]: client/aaa.bbb.ccc.ddd:33540 Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
Jul 1 20:17:46 ovpn-server1[14651]: client/aaa.bbb.ccc.ddd:33540 SENT CONTROL [client]: 'PUSH_REPLY,route 192.168.1.0 255.255.255.0 vpn_gateway 500,redirect-gateway def1,route-gateway 10.8.0.1,topology subnet,ping 15,ping-restart 60,ifconfig 10.8.0.2 255.255.255.0,peer-id 1,cipher AES-256-GCM' (status=1)
Jul 1 20:18:43 ovpn-server1[14651]: aaa.bbb.ccc.ddd:41782 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Jul 1 20:18:43 ovpn-server1[14651]: aaa.bbb.ccc.ddd:41782 TLS Error: TLS handshake failed
