Chuckles67
I used to be able to connect remotely into my home router VPN Server and access router GUI and network devices on the LAN DHCP Server (NAS, Mac).
e.g.: this was my post https://www.snbforums.com/threads/vpn-instructions-for-a-newbie.59478/post-670584
Unfortunately in my current setup running Merlin 386.7 I can still connect remotely into the router GUI but not to anything else on the local network.
UPDATE: I can connect to some devices - just not those behind a LAN switch (presumed faulty). There's really helpful suggestions in this thread, so leaving this up for the curious.
Current setup:
- home local network: AX-86U Merlin 386.7 running
VPN Server 1 on UDP/1194 (LAN only)
VPN Server 2 on TCP/443 (Both)
Various network devices: NAS devices x 2, Mac computer
- remote devices: Mac using Tunnelblick, iOS using OpenVPN
What still works
- web access to router GUI and ping to the router IP
- I can uses VPN Server 2 to remotely access the public internet through home network.
What does not work any more
- remote pinging and web access to local network devices (NAS/MAC) behind a LAN switch (likely faulty)
What’ve I tried:
1) checked my VPN Server settings are to Advertise DNS to Clients
2) stopped all VPN Clients (was 2x NordVPN), removed kill switch(es), and removed the VPN Director enable ticks. Note I did used to be able to have several VPN Clients running and access local network for all devices that were not routed through VPN clients.
3) tried adding policy-based routing in the VPN Director
192.168.50.0/24 10.99.0.0/24 WAN <or> 192.168.50.0/24 10.8.0.0/24 WAN
e.g.: https://www.snbforums.com/threads/s...allowed-at-same-time.66726/page-2#post-737620
192.168.50.0 0.0.0.0 WAN
e.g.: https://www.snbforums.com/threads/site-to-site-vpn-issue.66141/post-615436
Any other suggestions to restore remote access to local network through VPN Server?
Current setup:
What still works
What’ve I tried:
